Alienkid H5 C1 build
mrbombermillzy
Re: Alienkid H5 C1 build
Post by mrbombermillzy »
lol
For your sanity, I will post Monday! :D
alienkidmj12 wrote: Sat Sep 11, 2021 4:59 pm tried reflowing the pins for all 4 chips under the psu, now i get a black screen on powerup :)
I think the solder is lead free , so if you reflowed with leaded solder then you might have made things a whole lot worse. You will need to remove all the solder and refit new sockets. If you reflowed with just flux you might be OK.
alienkidmj12
Post by alienkidmj12 »
well, it doesn't appear to have made it worse, i'm back to a white screen.
unless i'm missing something here.
regards
dave
alienkidmj12
mrbombermillzy wrote: Sat Sep 11, 2021 8:33 pm lol
thank you
mrbombermillzy
alienkidmj12 wrote: Sun Sep 12, 2021 12:42 pm
thank you
You must have got the other board by now...any luck?? :)
alienkidmj12
mrbombermillzy wrote: Thu Sep 16, 2021 8:01 pm
thank you
came yesterday mate, tested it, i think it is the same issue, ive sent my board off to bomber, when its returned i will return your memory,
if thats okay
cheers
dave
mrbombermillzy
No worries. Hope you find out what the problem is.
I've received the board today and have taken a look at it and so far I've had to rectify some dry joints, then found one of the legs on the GLUE was nearly broken off, nothing I can do with that so I've had to swap it to carry out further tests.
The DMA chip was quite dirty with flux etc and didn't make a good contact in the socket, I've fixed that.
So now we have a H5 that isn't halted but also doesn't want to boot TOS. I've found an issue with A0 and D0 earlier not pulling up to 5v and have fixed that.
So time to cary on with this stubborn H5.
Good finds and diagnostics so far @PhilC. Hopefully there will be another living H5 soon.
So the conclusion from tonight's fault finding.
Found lots more dry joints on the pcb and had to change one of the bus pullups.
It now boots to Tos1.04 but it's not happy with floppy drives at the moment. It will happily format 80 tracks but then fail right after when trying to do the track zero seek, it tries 3 times and then fails. So I will need to work on that tomorrow.
Whilst trying to get the floppy working I found that the DMA chip had also given up. So that's a new GLUE and DMA chip required.
I've tried booting to the diag cart but it just ignores the card and boots tos instead. So either a bad connection on that or the port has had it.
And the most annoying of all, the DS1315 clock chip appears to be a reprinted fake. The H5 won't boot at all with it inserted.
Floppy fault hunting tomorrow. @alienkidmj12 what would you like to do about the failed chips?
Return to “H5 C1 USER BUILDS”
