Oops, my obsession with computers from my childhood strikes again!
@rubber_jonnie No I've not had time but I will do when I get. chance, in case its something of use for others.
Been looking at sound cards instead for me Apple.
Cool. Looking at soundcards as well, but need to wait a week for paydayPhilC wrote: Thu Sep 16, 2021 11:20 am @rubber_jonnie No I've not had time but I will do when I get. chance, in case its something of use for others.
This one was remarkably clean, I gave the heads a clean with IPA and running Locksmith speed test:
It's looking really very good, but the acid test will be to init a disk and copy something over too it. Need to just get a belt for the Seltron and I'll be good to go disk wise
EDIT: Init seems fine and dandy
@rubber_jonnie I've not tried that test program. I think one of mine needs a cap change as its a bit reluctant to work until it. "warms up" but the only other thing I had to do was lubricate the guide rails for the read heads as they were both squeaking when used.
@PhilC
I'd forgotten about the thunking they make when you use a disk for the first time after inserting.
@rubber_jonnie
Wow I still use neon lamp
to adjust my drives I feel old
Tom
Tom
NiceTomswork wrote: Thu Sep 16, 2021 2:44 pm @rubber_jonnie
Wow I still use neon lampto adjust my drives I feel old
Tom
Sadly I don't have a suitable neon myself or I'd do the same.
Somewhere I have a timing light for my car that used the same trick.
@PhilC Especially for you
@rubber_jonnie that looks familiar, I wonder where I've seen that setup before?
What is really handy is that the drive has a Drive 2 sticker on it so I don't forget which is whichPhilC wrote: Fri Sep 17, 2021 9:23 am @rubber_jonnie that looks familiar, I wonder where I've seen that setup before?![]()
@rubber_jonnie one is missing that, although the other drive has the drive 1 sticker.
