2600 Composite mod
Re: 2600 Composite mod
Ahh, cool, thanks. I will try and order tomorrow, I'll let you know if I have any problems.
I did look on Mouser with a slightly different part number and came up emty handed.
Wow, Mouser wants a minimum of £12 shipment on 5 chips. That's mad! Thanks though, as now I have that part number, I'm getting more results :)
And they're ordered :)
rubber_jonnie wrote: Thu Jul 05, 2018 9:08 am And they're ordered :)
:bravo:
Might be a idea to mount the board on a connector on the TIA so PCB can be easily removed.. IIRC a couple resistors may need tweaking..
exxos wrote: Thu Jul 05, 2018 7:25 pm
Yes, the thought had also crossed my mind that making it removable might be useful.
Are you talking about resistors on the PCB or the 2600 itself?
Ok, so the FMS6146-Ds have just arrived from UTSOURCE, worked out about 91p a chip, I have 10 now :)
Still waiting on the MAX7453s to arrive, they are due on Monday earliest unless the seller is telling porkies!
Ok, not much time tonight due to PSU rebuilds, but I made a start!
Given the chip is about 5mm square, I'm quite pleased with the soldering results, considering it was done by hand with an iron!
Looks like good connections under a magnifying glass so I'm hopeful it'll be good when I get it built.
:bravo:
I have no idea how that board works anymore :lol:
exxos wrote: Thu Jul 19, 2018 2:37 pm :bravo:
Damn, and I was hoping you could tell me!!
Aaaand the MAX7453s have just arrived. I see more soldering in my future. Just need to work out what I'm missing from the BOM now.
Return to “8 BIT CORNER”
