When SGIs come to play
This is my SGI Octane, which I'll be getting set up as soon as I can find my Octane 13W3-VGA adapter!!
I'll pull it apart and get some pics of the weird and wonderful insides sometime soon:
For now here's a selfie :)
Re: When SGIs come to play
I once raytraced a simulated cosmic microwave background around a simulated galactic cluster to see if the change in polarisation of photons was worth trying to detect on one of them.
The answer was no.
Carry on. :-)
Badwolf wrote: 15 Sep 2021 12:42 I once raytraced a simulated cosmic microwave background around a simulated galactic cluster to see if the change in polarisation of photons was worth trying to detect on one of them.
The answer was no.
Carry on. :-)
Lol!!
I shall carry on!
You can use the 3D file manager and pretend that you're in Jurassic Park.
stephen_usher wrote: 15 Sep 2021 13:32 You can use the 3D file manager and pretend that you're in Jurassic Park.
Not without my VGA adapter I can't :(
Well, you can pretend that you're seeing it too. ;-)
Looks like we have a small following of SGI fans here on exxos forum :) Me and @trixster both have Octanes too :) You should join the community at https://sgi.sh as they're developing current software stacks for Irix, it's awesome! :)
Btw... I think it is kind of cool that you can mount your Atari drive via NFS from Irix to FreeMint, and vice versa ;)
Steve wrote: 15 Sep 2021 13:58 Looks like we have a small following of SGI fans here on exxos forum :) Me and @trixster both have Octanes too :) You should join the community at https://sgi.sh as they're developing current software stacks for Irix, it's awesome! :)
Hmm, interesting, another forum for me to join :)
I actually have 2, but one isn't working and is a bit beat up. I'll have to get the HINV as I can't recall what it has, other than all SIMM sockets are full and it has 2 CPUs.
Cool - I guess it works enough to get to the PROM if you can do a hinv? Might just need to pull/reseat the CPU tray and graphics tray. Sometimes those compression connectors just need some movement.
Steve wrote: 15 Sep 2021 14:46 Cool - I guess it works enough to get to the PROM if you can do a hinv? Might just need to pull/reseat the CPU tray and graphics tray. Sometimes those compression connectors just need some movement.
The one pictured boots, the other just doesn't, but the PSU works in the other machine, but I need to test the other trays once I can find my 13W3-VGA adapter. I seem to recall they work, so it is something off in the chassis like the Xbow I could be in trouble. Of course it could just be the power switch :)
Users browsing this forum: Amazon [bot], apple [bot], ClaudeBot, Qwantbot and 14 guests
