Desoldering Rework Station sponge washers ?
Those of you that have this type of station...
Does anyone know Somewhere, preferably in the UK, that sells those small round washer things as highlighted in the image ?
I have been searching but can only seem to find them in the USA, which is bonkers :roll:
Re: Desoldering Rework Station sponge washers ?
I bought mine from here, located in Surrey:
https://www.ebay.co.uk/itm/193461777853
Found a kit in CPC so far..
https://cpc.farnell.com/duratool/d00672 ... -cQAvD_BwE
Steve wrote: 10 Sep 2021 15:19 I bought mine from here, located in Surrey:
Thanks, I just could not find them at all :roll:
Do you know why there is two different sizes ?
OH never mind :lol:
Duratool/Anesty ZD-915 Compatible Desoldering Filters
Available in the following two sizes:
17mm diameter (10 pack) - these filters go inside the glass barrel of the desoldering iron.
21mm diameter (6 pack) - these filters go inside the vacuum hose's entrance to the main unit.
kulamario
Post by kulamario »
exxos wrote: 10 Sep 2021 15:17 Those of you that have this type of station...
I have same desoldering station I use make-up removal pads just cut circle
@kulamario interesting idea, cotton being fire resistant to some extent.
kulamario
Post by kulamario »
I have been using this since I have run out of two that were in the set when I bought it
PaulJ_2.0
Post by PaulJ_2.0 »
I noticed these on Farnell:
https://cpc.farnell.com/duratool/d00759 ... dp/SD01419
They seem cheap
DoG
Post by DoG »
Felt pads for furniture legs is pretty much the same stuff.
Return to “ELECTRONICS”
