Found the OS1 switch, made no difference as far as I can see?
For me there was a slight change from black background to dark brown. Black background is mono, switch is on, Brown background is colour, switch is off.
Unless that weird ass mod is affecting the video output?
I think I shall remove the mod and put it back to standard. I'm wondering if this was used with some odd monitor and it needed a boost or something?
Could be, maybe you can remove the mod and chip as one, just put a new chip in?PhilC wrote: 09 Sep 2021 16:32 I think I shall remove the mod and put it back to standard. I'm wondering if this was used with some odd monitor and it needed a boost or something?
lilwashu
It should switch from mono to colour automatically depending on the screen output, except if the colour switch is off in which case it should be permanently mono.rubber_jonnie wrote: 09 Sep 2021 16:27For me there was a slight change from black background to dark brown. Black background is mono, switch is on, Brown background is colour, switch is off.
There are two adjustable pots on the right hand side of the board which adjust the colour signal - mine behaves differently on three different displays I have, on a mid 2000s LCD it is permanently in colour mode (brownish background instead of black), on a mid 90s CRT it switches from mono to colour with a slight delay, and on a late 80s CRT and a Philips monitor it switches over with no delay. This behaviour can be changed by fiddling with the pots.
So the dead bug chip was a 7407 logic chip. I've now removed it and lo and behold we have colour once again.
I'm thinking that was some kind of mono monitor mod?
Mine doesn't switch automatically, I suspect because the pots you've mentioned need tweaking because of my modern LCD display. I'll just leave it on colour for now, it's easy enough for me to switch on account of not having the display on top of the case.lilwashu wrote: 09 Sep 2021 16:39It should switch from mono to colour automatically depending on the screen output, except if the colour switch is off in which case it should be permanently mono.rubber_jonnie wrote: 09 Sep 2021 16:27
Splendid!PhilC wrote: 09 Sep 2021 16:41 So the dead bug chip was a 7407 logic chip. I've now removed it and lo and behold we have colour once again.
:girldance:
Slowly getting used to the Apple IIe, I can definitely say it does things differently than other computers I used at the time.
For instance Init to format a floppy disk rather than the format command on beebs and the like.
Just tried out one of my two 5.25 Disk II drives. Apart from the odd noise where it needs lubricating it's working pretty well.
Of course as usual I have stuff to learn like why is there a 3.5mm Jack socket and a switch on the front of the drive?
Also, if you have 2 drives it's init,D2 but then D2 remains active after that until you actively specify D1again.
As for the switch, maybe it's modded, worth taking a peek, or perhaps it's an ID switch? As for the 3.5mm jack, who knows, take a peek again I guess.
Users browsing this forum: ClaudeBot, nicknm and 20 guests
