MegaST2 won't start up properly
Yod801
Post by Yod801 »
I've got a MegaST2, which isn't properly working. When I switch on the machine, I only have a black screen. When I switch it on with the floppy drive disconnected, there is a flickering screen for a couple of seconds before it goes black.
However when I shortcircuit pin 17 and 18 of the CPU, it'll boot, but there are no icons on the desktop while the menu works correctly.
Someone before me soldered a mod ontop of the CPU as you can see in the picture below:
Please help. What can I do to solve this issue?
Yod801
Re: MegaST2 won't start up properly
Post by Yod801 »
I forgot:
Pin 18 shows 5Volts on a multimeter
Pin 17 just 0Volt
Atarian Computing
Post by Atarian Computing »
The mod is a factory installed blitter patch.
Clearly you already suspect the reset circuitry. Have you tried checking U2 7407?
Yod801
Post by Yod801 »
Sorry, I'm a n00b to hardware and electronics...
what is "U2 7407"? And what to check?
Broken reset switch ? Check RESET with meter to GND and press and hold reset button.. voltage should change between 0V and 5V.
Yod801
Post by Yod801 »
Tried to. Reset switch seems to be broken. What to do now?
Yod801 wrote: 02 Jul 2018 16:10 Tried to. Reset switch seems to be broken. What to do now?
Replace the switch ?
Yod801
Post by Yod801 »
How? Do you sell any switches? Let's say, I don't necessarily need the switch. Can I just remove it?
Yod801 wrote: 02 Jul 2018 16:21 How? Do you sell any switches? Let's say, I don't necessarily need the switch. Can I just remove it?
You mentioned earlier that you weren't too great with electronic stuff and hardware, so don't do this if you aren't competent at soldering.
Exxos has switches here: https://www.exxosforum.co.uk/atari/store2/#0114
Yod801
Post by Yod801 »
Don't worry, my neighbour studied physics and technical computer science. He'll make it. Ordered the switch
