No, you need the XC95144XL CPLD (the same one used on the TF330).GadgetUK164 wrote: 01 Sep 2021 18:21 Sorry if this is an obvious question - about to order the IC's, I dont see them mentioned on the bom XLS files? Is it just the same ICs used with the 536?
TF1230 Beta Interest (Open Source)
alenppc
- Moderator Team
Re: TF1230 Beta Interest (Open Source)
GadgetUK164
Thanks, what about RAM and the other chips on there (buffers)? Is there a specific speed of that CPLD required?alenppc wrote: 01 Sep 2021 18:23No, you need the XC95144XL CPLD (the same one used on the TF330).GadgetUK164 wrote: 01 Sep 2021 18:21 Sorry if this is an obvious question - about to order the IC's, I dont see them mentioned on the bom XLS files? Is it just the same ICs used with the 536?
alenppc
- Moderator Team
The buffers & RAM are the same as the 536, and the CPLD speed is the usual 10ns.GadgetUK164 wrote: 01 Sep 2021 18:26Thanks, what about RAM and the other chips on there (buffers)? Is there a specific speed of that CPLD required?
GadgetUK164
Thanks! Ordered from Mouser - CPLD wont be here until October - best of a bad situation really. Couldnt find the parts in stock across all the suppliers I tried. This chip shortage thing is getting worse it seems...
arkadiusz.makarenko
- Moderator Team
Btw Thank you @go0se for supplying me with nice kit. Sourcing parts (including proper 50Mhz 030! - first I ever seen) would take me ages.
Ps
Pay attention to to buffer orientation, unless you want to have nicely toasted finger.
Ps
~ Stanislaw Lem
~ Stanislaw Lem
alenppc
- Moderator Team
Yes! Everything is starting to get out of stock, even the most basic parts. It's very annoying.GadgetUK164 wrote: 01 Sep 2021 19:08 Thanks! Ordered from Mouser - CPLD wont be here until October - best of a bad situation really. Couldnt find the parts in stock across all the suppliers I tried. This chip shortage thing is getting worse it seems...
Danoo
:?: :?:alenppc wrote: 01 Sep 2021 18:23No, you need the XC95144XL CPLD (the same one used on the TF330).GadgetUK164 wrote: 01 Sep 2021 18:21 Sorry if this is an obvious question - about to order the IC's, I dont see them mentioned on the bom XLS files? Is it just the same ICs used with the 536?
Ordered my parts straight off the 1230 Schematic file in Eagle that file is showing a XC95288XL as the CPLD
- Admin sponsor
Ah sorry.. its the same footprint and its pin compatible.. you'll just need a different jed
Danoo
Is that a hassle producing a different jed :?: If so, no problem will simply put the build on hold, and order a XC95144XLterriblefire wrote: 01 Sep 2021 20:20Ah sorry.. its the same footprint and its pin compatible.. you'll just need a different jedDanoo wrote: 01 Sep 2021 20:03
- Admin sponsor
The 288 is alot more expensive so if you can swap it i would
Users browsing this forum: ClaudeBot and 195 guests
