TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: TF1230 Beta Interest (Open Source)
Post by arkadiusz.makarenko »
Where can I find firmware?
I have almost completed building my one, just cleaning drying etc (...yes it still may take me few days to complete it)
~ Stanislaw Lem
Here is the latest i have .. it has some glitch correction for the clock.
I would recommend people do not do large PCB orders at this stage. I'm planning a rev 2.
tf1230r1_main_top.zip
(12.67 KiB) Downloaded 185 times
alenppc
Moderator Team
Moderator Team
Post by alenppc »
This version does the reset flash, and then shows the yellow screen that goes back to grey and then back to yellow. The old version went straight to yellow screen and stayed there.
supaduper
Post by supaduper »
Same as Alen I do get an IDE flash which did not happen before, then mine can go to purple screen sometimes
This is with MX roms, still boots fine on Cmorleys roms though
go0se
Post by go0se »
Behaviour seems to be different on each power on with this one. 1D.4 motherboard, 3.1 MX ROMs
Yellow/Mustard screen on power on, flicks to grey after ~4 seconds and back to yellow then grey constant.
Yellow/Mustard flicks to grey then to black and stays black (still with signal).
Still boots and runs on a 2B.
kulamario
Post by kulamario »
This photo is for Board 1d4 kick 3.1
Reamiga start booting
chucky
Post by chucky »
terriblefire wrote: Tue Aug 31, 2021 9:21 pm Here is the latest i have .. it has some glitch correction for the clock.
It is a beta. hopefully noone makes large pcb orders of a BETA?!?
go0se
Post by go0se »
chucky wrote: Tue Aug 31, 2021 10:25 pm
All you suckers buying dribs and drabs, go big or go home! the more you buy, the more you save!! 8-)
arkadiusz.makarenko
Moderator Team
Moderator Team
Damn. My set up seems to be good one. It works OK (boots to kick screen, and passes RAM test on Amiga Tool Kit.
ReAmiga 1200 1.2, based on 1D4 donor. All chips were lifted from old board, so only passives and transistors are new)
Kickstart 3.1 EPROM.
I didn't boot to Workbench as my CF is configured for TF1260, so need to create new one to test this 100%.
I may try my old 3.0 MX kicks later today.
~ Stanislaw Lem
GadgetUK164
Post by GadgetUK164 »
Sorry if this is an obvious question - about to order the IC's, I dont see them mentioned on the bom XLS files? Is it just the same ICs used with the 536?
Return to “TF330”
