STE VIDEO GHOSTING FIX
The latest tweaks and fixes to keep your machine running in tip-top shape.
While I was developing my replacement AtariPSU I noticed the video quality improved immensely. However, I still saw some "ghosting" on the display which baffled me for a few hours. While ghosting can be other factors, such as bad video cable, ora bad LCD TV, for me the problem was on the Atari itself. On the left is the image before my fix, and on the right is after my fix. The left image shows ghosting to the right of the Atari Fuji and at the ends of the black box lines. While the ghosting is faint, it can still be seen clearly compared to the image on the right. Thankfully the fix is a easy one..NOTE - This mod was to fix RGB/scart issues and has not been tested with RF or Composite video signals.
Near the top left of the simms there is a yellow capacitor (C411) which needs more capacitance across it. The odd-ish thing is, R544 is actually a 8V regulator feed from the 12V rail. Normally I would have expected good regulation there, and it is, but its still not good enough to solve the video problems.
The results are...
1uF ceramic doesn't fully solve the ghosting problem.
10uF electrolytic probably 95% solves the problem.
47uF seems to work best, may improve a couple % with the 1uF in addition.
So a 47uF capacitor with the possible addition of a 1uF ceramic seems to fix this issue. Larger values than 47uF can be used, but I wouldn't recommend going below 47uF. Like I keep saying over and over in other pages on my site, you NEED low ESR capacitors otherwise "any old capacitor" will not work! Look towards Panasonic FR range of capacitors.
That's it! Enjoy your ghost free display :)
Another couple of images of ghosting issues (and fixed ) on a STE I wasservicing today..
MSTE VIDEO GHOST FIX (WIP)
I had a MSTE in for repair so I looked into solving the ghosting issue.It was only slight on this machine, so capturing a image proved difficult.However with soldering a low ESR 10uF capacitor across C506 as shown inthe above image removed what little ghosting I saw.
If anyone can verify this and take images on their own MSTE then it wouldhelp.
HOME PAGE
http://www.exxosforum.co.uk/atari/last/V ... /index.htm
redhawk668
Re: STE VIDEO GHOSTING FIX
Post by redhawk668 »
I did this fix too, on my 1040 STE. I am running my STE through a SCART/HDMI converter and this has improved the image quality significantly. Very happy with it.
My collection: 1040 STE, TOS 2.06, 4 mb, CosmosEx - 520 STFM, TOS 1.04, 4 mb, Blitter, CosmosEx - 520 STFM, TOS 1.04, 4 mb - 1040 STF, TOS 1.04, 1 mb, Gotek - Amiga 1200 with Blizzard 1220/4 - Amiga 500 + ACA500 - Amiga 500 + TF530, 1 mb chipram hack.
Atari 8 bit: 800XLF, stock - 600XL, Ultimate 1 mb, Sophia RGB - 130XE, 320 kb, Sophia RGB
Sinclair stuff: 3x Spectrum 48KB, Clones: Harlequin, JS128, Nuvo128 and Issue3B replica.
Ultimate64, a few C64 breadbins and Pi1541 for storage.
redhawk668 wrote: 11 Feb 2018 18:54 I did this fix too, on my 1040 STE. I am running my STE through a SCART/HDMI converter and this has improved the image quality significantly. Very happy with it.
Nice one, thanks for letting me know!
BlankVector
Post by BlankVector »
Hey, that's amazing :ugeek:
Subscribe to my Vretrocomputing channel on YouTube and Facebook. Latest video: Display a color pixel in assembly language on Atari ST.
redhawk668
Another thing is, I’ve connected the HDMI converter to a VGA connector and connected it to a 5:4 ratio Acer AL1917 VGA LCD screen, image quality is great and it has built in speakers. So, basically the converter works as a scandoubler/scaler. I use it with all my retro computers not only my Atari ST’s. I got this screen for free and after gathering dust on the shelf, I decided to put it to good use. I am very happy with this screen ;)
redhawk668 wrote: 13 Feb 2018 21:15 Another thing is, I’ve connected the HDMI converter to a VGA connector and connected it to a 5:4 ratio Acer AL1917 VGA LCD screen, image quality is great and it has built in speakers. So, basically the converter works as a scandoubler/scaler. I use it with all my retro computers not only my Atari ST’s. I got this screen for free and after gathering dust on the shelf, I decided to put it to good use. I am very happy with this screen ;)
Nice :) why not post your setup with some screenshots over on this section https://www.exxosforum.co.uk/forum/viewforum.php?f=30 :)
sandord
Post by sandord »
I did the fix as well and it works perfectly! Video looks as clean as it can get. :dualthumbup:
vertical
Post by vertical »
I am about to do this fix, however, I haven't noticed this ghosting on GEM. I am using a multiscan CRT monitor, not TFT. Does it apply on CRTs as well? I defo see ghosting in Bad Apple on a CRT.
vertical wrote: 30 Aug 2021 14:49 I am about to do this fix, however, I haven't noticed this ghosting on GEM. I am using a multiscan CRT monitor, not TFT. Does it apply on CRTs as well? I defo see ghosting in Bad Apple on a CRT.
Just try it out and see for yourself.. there is nothing to lose.
CRT's Are probably just not good enough quality to see the ghosting like modern LCDs are. No harm in doing it anyway.
Return to “TWEAKS & FIXES”
