Problem with H4 not booting (zChris's board)
Re: Problem with H4 not booting (zChris's board)
Yes i broke the 1.04 one. But i have tried with board and without board, both roms the left and both banks of those roms. So far its the same. A question. If there is no correct rom will the screen go black when pressing the reset anyway ?
Here are the current data after i "fixed" the A12 line:
A1-A15
A1-A15
With the decoder. The HALT signal does not go LOW. AS gets stuck at 1.4v - 1.5v. And on A1 there is an sinus wave that seems to stretch the future down the addressline i measure. Like A1 has a little bigger sinus wave than A0, A2 a little bigger than A3 etc up to like A6 where i stopped measuring.
Dont know if this is just gibberish or if it give some clue to something.
/zChris
/zChris
Address lines floating up and down sounds like your pull-ups are not pulling up!
I'm confused what that last scope line is supposed to be, before you stated
So deadliness look fine if they are the top waveform. Same with AS. So I don't know what "analogue adressline" is referring to, I just assume that scope probe was not connected.
In anycase, with all address lines showing zero (can you confirm they are all zero on the ROM also ?) You should have
01100000 00101110
But your data shows
0110000 00000000
It looks like you should check LDS, UDS are both zero when AS is low. High byte looks correct, but lower byte is totally wrong. But even so, LDS,UDS does not effect the ROM as it is driving the bus in 16 bit mode regardless. If anything they should still be correct AFAIK. But worth just double checking LDS,UDS connections from the CPU to GLUE, and check they are all zero after reset also.
But again, the ROM drives the bus, and nothing on the bus can drive it low during ROM access, other than the ROM itself. So if ROM is bad, the data will be wrong. If the address on the ROM is wrong then the data will be wrong. There really is nothing else in the circuit to corrupt the data in such a way. Other than the blitter..
So might be a idea to take out the ROM, and scope out the databus after reset to see if you get all 1's (no need to post scopes of them all) just confirm if they all high without the ROM. If they are not, maybe the bus buffers have failed, or MMU isn't driving them.. but one step at a time..
Channel 0 at the top is Adressline, Channel 1 is AS and Channel 0 at the bottom is analogue adressline.
01100000 00101110
But your data shows
0110000 00000000
UDS and LDS are low the first four AS Low but on the fifth AS low UDS and LDS are high, not sure if that has any significance. UDS and LDS also have connection with GLUE.
All the data lanes are 1 when AS are low. There is a difference though between some data lanes. When i hold reset all data lanes EXCEPT 2 , 3, 4 are high. On lane 2 , 3, 4 they are low when i old reset and become high when i release it.
Both these test were done with ROM not in the socket and A12 "patched".
/zChris
/zChris
I believe that "analogue adressline" (with a little 'A0' tag on the left) means the actual voltage of the address line on the probe, and then "channel 0 at the top" (marked 'D0') as well as Channel 1 (marked 'D1') are the interpretations as logic high/low (in other words a logic analyser).exxos wrote: Sat Aug 21, 2021 11:55 pm I'm confused what that last scope line is supposed to be, before you stated
Am I right @zChris ?
But its nowhere near following the top 2 signals.. They are switching fast , that bottom signal is not..sporniket wrote: Sun Aug 22, 2021 7:17 am]
This seems to indicate the ROM IC is bad or the socket isn't contacting to the ROM properly.. There's no other way it can put bad data on the bus other than the address lines are bad to it.zChris wrote: Sun Aug 22, 2021 2:08 am Both these test were done with ROM not in the socket and A12 "patched".
