TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
kulamario
Re: TF1230 Beta Interest (Open Source)
Post by kulamario »
The amiga has been running for almost 24 hours
I did some tests but I don't see any problems
wdhload works great game demos etc
I left the doom on all night and everything works as it should
Yeah same result as me. Seems to be hit or miss if it works on an A1200 or not. If it works its fine. Are you on OS3.2? OS3.2 seems to work better on some machines.. Others work perfect with both. I havent got an Amiga that doesnt work.
kulamario
Post by kulamario »
terriblefire wrote: 19 Aug 2021 13:07 Yeah same result as me. Seems to be hit or miss if it works on an A1200 or not. If it works its fine. Are you on OS3.2? OS3.2 seems to work better on some machines.. Others work perfect with both. I havent got an Amiga that doesnt work.
Now I on 3.1
I have 3.2 but not test yet on tf1230
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
What are chances that it is 030 cpu related?
~ Stanislaw Lem
arkadiusz.makarenko wrote: 19 Aug 2021 14:38 What are chances that it is 030 cpu related?
Absolutely zero.. Because the same physical card that didnt work for Chucky was mailed to me and works fine here. Is purely down to the A1200s.
terriblefire wrote: 19 Aug 2021 14:54
We even did a Jens and checked power supplies.
kulamario
Post by kulamario »
I did some tests on wb3.2
from the first glance you can see that it all goes faster
chucky
Post by chucky »
weird. put up my test reamiga.. with a 1230. it crashed and hanged during IDE loading etc.
flashed with the new firmware from Stephen. even if he claim nothing is changed. now it boots fine and seems to run on that machine here.
weirdly it DID work before. bnut now decuded not to. only change I have done is put in another alice. but that is impossible to be a reason..
anyway. it runs here now suddenly. more tests to be done. but running some 030 demos works.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
Mine still yellow-screens. I have to check if I messed up the patch wire (although it works with the 14 mhz fw).
Well we've gone from a 2/3 not working rate to a 1/4 not working rate.
Return to “TF330”
Users browsing this forum: ClaudeBot and 12 guests
