I specifically remember because I initially didn't install it as I misunderstood the requirements. Then I had major problems and had to add a bodge wire to fix.PhilC wrote: 16 Aug 2021 17:48 @rubber_jonnie I'd initially thought rom but had forgotten about the LS11 :-D
Problem with H4 not booting (zChris's board)
Re: Problem with H4 not booting (zChris's board)
zChris
Nothing happens when i press reset on the jumper, it is constantly on 5V. Should it be that?exxos wrote: 16 Aug 2021 18:48 You need to check that line I highlighted.. but check it on the jumper on your scope and keep pressing reset to see if it changes.
/zChris
Nope, what about reset pin on cpu ?zChris wrote: 16 Aug 2021 19:04 Nothing happens when i press reset on the jumper, it is constantly on 5V. Should it be that?
zChris
Reset (Pin 18) goes to low (0v) when reset button is pressed and high (5.2v) when it is released.
/zChris
/zChris
zChris
Measuring when the reset button is pressed in i got 0.2 on Pin 23,17,4,3,2. When releasing reset pin 17,4,3,2 went from 0 -> 5V and then down to 0 again. Nothing changed on Pin 23.
/zChrus
/zChrus
@zChris for clarity, you are checking at a dip socket not the plcc one for the cpu?
zChris
Have i done the calculations correctly here.
6 squares from top to top = 6x20ns=120ns=0.00000012s
Then 1/0.00000012 = 8333333.33333roughly 8.3Mhz ?
/zChris
/zChris
zChris
Im checking in the expansion port. Thats wrong?PhilC wrote: 16 Aug 2021 20:05 @zChris for clarity, you are checking at a dip socket not the plcc one for the cpu?
/zChris
@zChris no that's fine, just checking so everyone knew.
Just press the measure button and select frequency.. then it will tell you the frequency..
