Old TT motherboard restoration
Re: Old TT motherboard restoration
It shouldn't crash without termination, merely not see anything. Sounds like your SCSI controller chip is probably fried.
frank.lukas
Post by frank.lukas »
Use the NVRam Soft from Uwe Seimet (HDDriver) to set the machine (TT) SCSI ID to 7.
mgi
Post by mgi »
Will try and if not I guess new SCSI chip?
frank.lukas
You need a 6V NVRam Battery for the Mainboard ...
4x AAA batteries in a holder works wonderfully (and cheaply).
The TT will run without one, or at least mine did for a while.
mgi
Post by mgi »
Well, I plugged again external SCSI HDD and added terminator at its end as I happened to have one and it works. I can run Mint and no surprises as of yet. I plugged the battery but 3.5V - seems to be holding watch and date - should I change it?
Big thanks - process ongoing
Michal
