NEC Multisync LCD
All information relating to connecting your ST to a modern TV/monitor.
IngoQ
NEC Multisync LCD
Post by IngoQ »
...continuation from thread here: https://www.exxosforum.co.uk/forum/viewt ... =876#p6386
mrbombermillzy wrote: 07 Jun 2018 20:30 Thats all well, (I have an NEC 1990FXp, fairly similar to your monitor) however, its not really what I was trying to achieve. Was really after the extra pixels! :D
Just out of personal interest, can you can confirm, that the 1990FXP handles 15Khz like i.e. the 1990SXi does, including adjustment options for 1:1 scaling etc.? There are a couple of them available on ebay right now, and I am thinking of getting one...
Ingo :geek:
troed
Re: TT Software overscan?
Post by troed »
IngoQ wrote: 08 Jun 2018 09:23
Well I can confirm 15KHz, don't know about other settings. My favorite is still the Dell 2001FP when it comes to picture quality, but the Nec is better in that it doesn't need "nudging" every boot to center the picture ...
IngoQ
Post by IngoQ »
Sadly I only have a Dell 2007, which does not handle 15Khz, although it has composite and even S-Video inputs... And its resolution is too high.
Right now I route everything under 31kHz through the Framemeister, which is not bad. But it means I have to switch inputs, since the Framemeister doesn't like 31kHz on its SCART-input...
Ingo :geek:
IngoQ
Post by IngoQ »
Had a look at some manuals, seems like only the NEC 1990SX and 1990SXi offer options to adjust the scaling.
Ingo :geek:
Atarian Computing
Post by Atarian Computing »
Not all monitors are created equal.
I have a Dell 2001FP that won't do 15Khz (manufactured after 2005)
My NEC 1550M won't do 15khz although many report that their's do
My NEC 1990SXi won't do 15khz when several say their's do
My BenQ 702 is currently the only monitor I have that can do 15khz.
I guess I'm just unlucky.
IngoQ
Post by IngoQ »
I guess, I stick with my current solution then ;) Already have too many displays standing around...
Ingo :geek:
mrbombermillzy
Post by mrbombermillzy »
@IngoQ:
Yes the 1990FXp does pretty well. As Ive mentioned before (on AF fairly recently I think) it will handle most of the funky Amiga modes (15Khz and up) but NOT any of the interlace ones. So the 3 Atari ST modes are possible.
I THINK it scales 1:1 although Im not 100% sure. It may be a long while until I can check... Maybe better off asking Troed about this. :)
IngoQ
Post by IngoQ »
Just received a NEC 1970NXP, which so far does fine with Amiga resolutions and ST high. Will order a UBE switch some time soon and then do a small writeup about it in the displays and converters section.
Ingo :geek:
Atarian Computing
IngoQ wrote: 17 Jun 2018 14:07 Just received a NEC 1970NXP, which so far does fine with Amiga resolutions and ST high. Will order a UBE switch some time soon and then do a small writeup about it in the displays and converters section.
Just bought 3 1990FX monitors. Yet to receive them. Hopefully they will do 15khz.
IngoQ
Post by IngoQ »
Only downside I have found so far: There is no adjustment for the scaler. It seems to automatically scale for horizontal resolution, which is fine, as long the vertical resolution fits the screen. If not, you're screwed :) You can adjust horizontal size but not vertical. In the Amiga Budbrain Megademo for example, some parts of the frame are missing.
Ingo :geek:
Return to “DISPLAYS & CONVERTERS”
