New SCSI Solutions for Atari/Amiga!
Cyprian
Re: New SCSI Solutions for Atari/Amiga!
Post by Cyprian »
@Steve what about RaSCSI speed?
http://260ste.atari.org
Cyprian wrote: 07 Jun 2021 22:18 @Steve what about RaSCSI speed?
Cyprian
Post by Cyprian »
nice result
Inception or what? The Falcon SSHing into its own RaSCSI :) I bet I could even enable X forwarding to run modern Linux apps on the Falcon X server :D
beel1
Post by beel1 »
Steve wrote: 07 Jun 2021 22:37
Seeing the heatsink: is your Pi overclocked?
I've never achieved more than 800kb/s with my stock Pi3B+ even on a SCSI adapter in a modern PC
@beel1 No just stock clock speed. You're running a Rascsi also I assume? It could be the Micro-SD card, I am using a Sandisk C10 Ultra.
@beel1 I just remembered, on the rascsi wiki it says that the rascsi.service software is single threaded - and the Pi Zero is single core, so it might help.
https://github.com/akuker/RASCSI/wiki/Benchmarks
I suspect that the Pi 0 got higher scores because the RaSCSI software only uses one core. This gives the Pi 0 a slight clock speed advantage
PaulJ
Post by PaulJ »
Steve wrote: 07 Jun 2021 22:37 PXL_20210607_200032971.jpg
Thats not bad, a little better than the UltraSatan and a tad slower than the IDE interfaces. Guess I need to build the SW and try mine. :)
DaveC
Post by DaveC »
Looks like I got the BLUESCSI working ok with my STe and ICD adscsi adapter :mrgreen:
It didn't work powered off the SCSI cable or usb port though, had to use the berg connector for it.
@DaveC Nice! Have you run some file transfers to test stability? I find that even if TOS transfers OK, Kobold will show if there are issues.
Here is a good disk error check program by PP:
AHPT94.zip
