FPU Compatible Software
General Discussion, STOS.
Darklord
Post by Darklord »
Interest in this subject seems to pop up occasionally but I've never seen a list
started to cover it. So, with that in mind, I'm starting lists at all 3 major
Atari sites, (AtariAge, AtariForum and Exxos's Forums). I'll try to keep up with
what's posted and combine the lists at all three places as needed. We did
something like this with the mono compatible games list and it worked
fairly well.
Just to get the ball rolling (and I know some of these need to be corrected,
but it's a start):
  • Phase 4 System
  • Phoenix (object renderer)
  • Rosetta
  • Chronos 3D
  • Cybersculpt
  • Cyberstudio
  • Cubase
  • Mark Williams C
  • POV/POVRay
  • Zero-X (Falcon version)
  • Lattice C
  • DynaCadd
  • Neon
  • Scape882
  • Inshape
  • PureC
  • LAME mp3 encoder
  • l'Abbaye des Morts (Falcon only)
Thanks everyone.
PaulJ
Re: FPU Compatible Software
Post by PaulJ »
@Darklord , are you saying that lattice C and Mark Williams C are capable of compiling code that used the FPU on a MSTE? If so I'll that would be pretty nice. :thumbup:
Darklord
Post by Darklord »
PaulJ wrote: 05 Jun 2021 02:34 @Darklord , are you saying that lattice C and Mark Williams C are capable of compiling code that used the FPU on a MSTE? If so I'll that would be pretty nice. :thumbup:
It's what I read when I did some searching. Of course, the posts were along
these lines:
"I think Lattice C can code to take advantage of an FPU".
That kind of thing.
I threw both titles out there hoping some one could verify or not.
We'll update the list as we find out more info.
Did this with the mono games list and it worked good. Wound up
with a list of games that work mono that was a whole heckuva
lot longer than we thought it would be.
Hopefully, the same thing will happen here... :)
pixelpusher
Post by pixelpusher »
Add PureC to the list...
thorsten.otto
Post by thorsten.otto »
Strictly speaking, compilers do not generate code that explicitly supports a memory-mapped FPU. It is only a matter of the library.
But are such software compatible with linef / io mapped ?
I was quite interested in some of those 3D packages you listed, seems they are all of the same family called 'Lexicor Phase 4' Nice article here:
https://www.atarimagazines.com/startv5n ... s.hym.html
Seems they can output Pixar renderman compatible files, I actually have an SGI with Pixar renderman on, would be cool to design something on my TT and then render it on my SGI :D Does anyone know where to download these software packages?
I found a thread on AF where they uploaded the CD image, but the links are long-gone:
https://www.atari-forum.com/viewtopic.php?t=29481
pixelpusher
thorsten.otto wrote: 05 Jun 2021 08:17 Strictly speaking, compilers do not generate code that explicitly supports a memory-mapped FPU. It is only a matter of the library.
Some time ago I stumbled over the archive for fpu_emu (.zip) by H. Robbers & V. Hemsen. While being limited to support the memory mapped 68881 via LineF, it allows using the same FPU code that you would have used on system with 68020 (or newer) with FPUs.
Limitations as far as I could see are:
- no 68882 support in the LineF emulation, only 68881
- cookie support is there, but doesn't consider modifying the system's FPU cookie to make sure LineF based code is used by other apps
czietz
Post by czietz »
pixelpusher wrote: 05 Jun 2021 13:15 Some time ago I stumbled over the archive for fpu_emu (.zip) by H. Robbers & V. Hemsen. While being limited to support the memory mapped 68881 via LineF, it allows using the same FPU code that you would have used on system with 68020 (or newer) with FPUs.
We just discussed a similar program (once published in c't magazine) over at AF: https://www.atari-forum.com/viewtopic.php?f=14&t=40516
thorsten.otto
pixelpusher wrote: 05 Jun 2021 13:15 - no 68882 support in the LineF emulation, only 68881
Question is: have there ever been SFP-004 boards with an 68882 FPU?
That would not make much sense. Applications are either compiled to use LineF instruction, or not (in which case they sometimes fallback to use a memory-mapped FPU). But i don't know of a single application that checks whether LineF is present, and only then uses it. That would be near to impossible.
Return to “SOFTWARE”
Users browsing this forum: ClaudeBot and 30 guests
