Hi all,
Is anyone making the TF CD32 riser and selling it to the Amiga community?
Cheers,
Matt.
Where to buy a TF CD32 Riser
matt020
arkadiusz.makarenko
- Moderator Team
Re: Where to buy a TF CD32 Riser
I have 2 spare, but you are too far away to make it work. :(
~ Stanislaw Lem
~ Stanislaw Lem
wairnair
Builders like superduper will be able to produce us a couple of boards?
Once its complete of course - how far do you think that is? No rush absolutely just interested.
alenppc
- Moderator Team
Maybe I can build a very small number of these, thinking about 5 max. Although it won't happen for a while since the AMP connectors are out of stock everywhere and won't be back till mid April.
I always wondered who cleans out all of these resellers periodically, I would have thought that the CD32 community would account for 90% of the sales but clearly not.
Cobe
Hi guys!
Does anyone have one 4 layer riser for cd32 for sale?
I bought A1200=>CD32 adapter from Edu but totally forgot that my old Hefesto riser is 2 layer...
Cheers
Cheers
- Admin sponsor
Why do you need 4 layer? If you want these ones you can order them as they're open source.Cobe wrote: 28 May 2021 09:41 Hi guys!
Cheers
Cobe
Cause adapter is not working with 2 layer raiser.(tested myself)terriblefire wrote: 28 May 2021 10:31Why do you need 4 layer? If you want these ones you can order them as they're open source.Cobe wrote: 28 May 2021 09:41 Hi guys!
Cheers
Here's what Edu wrote:
"It will work with my lastest Hefesto Riser and probably will work with others risers if they are 4 layers and with all the pins connected."
You mean I can order pcb, but I barely have any soldering skill...
- Admin sponsor
Hmmm? 4 layers vs 2 layers is not a functional difference in risers...Cobe wrote: 28 May 2021 12:31 Cause adapter is not working with 2 layer raiser.(tested myself)
@arananet what are you trying to explain to this man?
The A1200 -> CD32 thing is (IMHO) not a great solution because the CD32 has different timings from the A1200 (You will see lockups) and the CD drive will not work because A1200 cards do not do bus arb.
