BBC Model B No2. Will it live again!
Re: BBC Model B No2. Will it live again!
@rubber_jonnie what do you need burnt to eprom? I've probably got some 27c128 around here somewhere.
@stephen_usher @PhilC
@BennehBoy has sent me a PM offering to do it, so thanks both so much, but I should be OK.
I'll just go off and find the necessary ROM file for the OS and another for Tricky's diag ROM.
IC 43 change made no difference.
Also looking to pick up another, working this time:)
Buying a working machine?! Where's the fun in that? :lol:
I know.....
Tomswork
Do you have a good 6502 the mostek chips were lemons 🍋
Tom
Tom
Yes, and swapping it out makes no difference. Neither does swapping out the 6522 or booting in minimal config.
Well, as discussed on Stardot, the minimal config won't boot with the standard ROM anyway.
Oh, it won't? I missed that somewhere along the line!!stephen_usher wrote: 17 May 2021 09:27 Well, as discussed on Stardot, the minimal config won't boot with the standard ROM anyway.
I'd better go back and re-read, thanks.
By the way, with your minimal oscilloscpe do you see any activity on the address or data lines at the ROM socket when you switch on (with the CPU in, of course)?
I do as it happens, so I do think something is happening and it's trying to boot.stephen_usher wrote: 17 May 2021 10:10 By the way, with your minimal oscilloscpe do you see any activity on the address or data lines at the ROM socket when you switch on (with the CPU in, of course)?
I hopefully have some ROMs on the way to test with courtesy of @BennehBoy soon.
