Hi everyone,
I have a Teac fd-235hf 8549 -u5 floppy drive that I pulled from an AKAI sampler. It was working in there, which got me wondering if it is possible to modify it for use in a ST rather than it sitting in a box in box on a shelf. I was hoping someone might by chance have experience doing this previously.
thanks in advance,
Craig
teac floppy drive use in ST
Re: teac floppy drive use in ST
If it's set as DS0 then it should JustWork(tm).
mcdoug
Ah excellent thank you! I am struggling to find the jumper setting for this exact version, but found this link: http://oldcomputer.info/media/disk35/3fd0020a.pdf
In my understanding I could remove all jumpers except the one I have marked in green? Or do I also have to set to auto density?
I would assume that would be what is required..mcdoug wrote: 14 May 2021 20:43 In my understanding I could remove all jumpers except the one I have marked in green?
I have used one of these drives but it was like 20+ years ago, I purchased it because it boasted really good error correction or something, in the end I gave up with it is the worst drive I had ever used.
mcdoug
Haha thanks for that, maybe I will just put it in that box after all! :lol: I will give it a shot and let you know if I get it working. Thanks for the advice:)
mcdoug
My brother just gave me an old drive he had (he was goign to chuck it out even though it works!) It is a sony mpf920 which is now sitting in my spares box, does anyone have experience with this drive in their st? Is any modification required or is it just a case of setting to D0? thanks, Craig
@mcdoug ive had some success with that Sony drive but uou will need to change the drive I'd, by using soldered jumpers if I remember correctly.
Also works as a 1.44mb drive with the correct bits in your ST.
mcdoug
Amazing thank you, that is just what I needed!
