Simple ST2VGA adapter
Methanoid
Post by Methanoid »
Was wondering differences between the IN STOCK ST2VGA and the UNAVAILABLE UbeSwitch
I can see the Ube
--adds trim pots for colour - are they needed?
--adds volume control - most monitors or speakers have this dont they?
--autodetection of resolution (in software) - no idea if this works, last time I looked at it, it was a WIP
can you change the jumper with ST switched on? ISTR it just resets for Hi or Lo/Med resolutions - is there a reason it doesnt have a slider rather than a jumper?
Re: Simple ST2VGA adapter
UBE info is here... https://www.exxosforum.co.uk/forum/viewt ... =161&p=708
As to if you need a volume control and other features, really depends down to user preference.
Methanoid
Post by Methanoid »
Thanks, I bought it and it arrived (quickly, thanks!)
Havent dug out my 15kHz monitor yet but plugged VGA into monitor. I got vertical bars which I have seen before on STs. I am pretty sure its NOT the adapter but there is some fix (as Ive had it before years ago).
Can you suggest fixes please?
Methanoid wrote: 04 May 2021 12:16 Can you suggest fixes please?
This question comes up every couple of weeks, other than changing scaling on your monitor which may be causing vertical bands, or invest in a more modern motherboard like the H5. such faults are just inherent design faults in the original motherboards and are not really easily solvable.
czietz
Post by czietz »
In almost all cases these bands are caused merely by incorrect monitor settings. Try the "auto" setting button. If that doesn't work, try adjusting the setting that might be called "clock" or "pitch" : http://www.techmind.org/lcd/phasexplan.html
Methanoid
Post by Methanoid »
czietz wrote: 04 May 2021 13:01 In almost all cases these bands are caused merely by incorrect monitor settings. Try the "auto" setting button. If that doesn't work, try adjusting the setting that might be called "clock" or "pitch" : http://www.techmind.org/lcd/phasexplan.html
Thanks, thats the sort of thing I did a few years back to fix the issue... Will try
Users browsing this forum: ClaudeBot, jmorden, peters, Reylan and 5 guests
