TF536 Firmare Update RC3
alexandregatt
Re: TF536 Firmare Update RC3
Hello, after this update, I have no more bugs. Thanks for this work. Everything is perfect...
matt020
Has anyone (other than GadgetUK) got SCSI cards to work with TF536 after the RC3 firmware update?
LIV2
Works fine for me here with an A2091matt020 wrote: 21 Apr 2021 02:22 Has anyone (other than GadgetUK) got SCSI cards to work with TF536 after the RC3 firmware update?
Gleylancer
Is this the only way of updating the TF536? I'm baffled by the sheer amount of hardware and effort that's needed to do this. O.oobitus1990 wrote: 02 Apr 2021 03:28I found this to be very helpful:Seb132 wrote: 02 Apr 2021 02:46 Is there a post for Newbies with a "how-to" tutorial explaining how to flash a TF on general and a TF536 in particular ?
I'm in Australia and never done this before...
Also is there a sticky post for all the latest firmwares of all TF cards ?
I have a TF330 also and I'm not sure what is the latest firmware for it and if I have it...
Thank you.
https://linuxjedi.co.uk/2020/12/01/prog ... pberry-pi/
- Admin sponsor
Baffled why? Thats the cheapest way to do it. You can buy an expensive XIlinx programmer as an alternative.Gleylancer wrote: 11 Jun 2021 20:27 Is this the only way of updating the TF536? I'm baffled by the sheer amount of hardware and effort that's needed to do this. O.o
alenppc
- Moderator Team
It's really not that expensive, $30 on ebay.terriblefire wrote: 11 Jun 2021 20:33Baffled why? Thats the cheapest way to do it. You can buy an expensive XIlinx programmer as an alternative.Gleylancer wrote: 11 Jun 2021 20:27 Is this the only way of updating the TF536? I'm baffled by the sheer amount of hardware and effort that's needed to do this. O.o
Gleylancer
As a naive and highly inexperienced amiga newbie, I was probably expecting to just do it from one of the internal storage options, but I suppose that's not possible.
Gleylancer
That looks like a much easier way, I'll just get one of those. Thank you.It's really not that expensive, $30 on ebay.
alenppc
- Moderator Team
Please be aware that you will most likely need a 32 bit windows to run the Xilinx ISE (14.1) and the programmer drivers. Even if you have an old WinXP machine it will be fine.Gleylancer wrote: 11 Jun 2021 20:52
BennehBoy
There's a workaround to get it to work on 64bit win10, couple of files to replace. Details on here -> https://alchitry.com/pages/installing-isealenppc wrote: 11 Jun 2021 21:06Please be aware that you will most likely need a 32 bit windows to run the Xilinx ISE (14.1) and the programmer drivers. Even if you have an old WinXP machine it will be fine.Gleylancer wrote: 11 Jun 2021 20:52
