Falcon maintenance
Re: Falcon maintenance
Oh will have to check the stock, PM me your address and will send the cap. It's not as critical to replace as the other caps.
stween
So help me understand this:
My falcon measures as marginally slower than the reference system? :o
Wait states set correctly? https://www.exxosforum.co.uk/atari/last/FALCWS/index.htm
assuming you are running a totally clean system on boot up as well ?
stween
Clean boot, running from cartridge, no HD, blank floppy in A.
I haven't futzed with the TOS/wait states stuff yet. On U46, currently jumpers 1 & 4 are soldered. The TOS chip in the system reads 4.04, C303217-001 on the front, 31472-20 PC240 (Singapore) on the back.
What's the correct/best/safest combination for U46? I have a 4.04 ROM from your store, so I can easily switch over to that.
If you have a ROM from my store, just look at the link I posted above for best settings..
stween
Okay, sure. I read this as: 1st, 3rd, and 4th jumpers.; I'll give it a shot this weekend. I had hoped to see straight 100%s before doing it, hence my question :)exxos wrote: 23 Apr 2021 13:49 If you have a ROM from my store, just look at the link I posted above for best settings..
Falcons have wait states enabled by default, because the ROMs they used was not quite fast enough for full speed access. All the ROMs in my store are fast ROMs, so they will always work correctly at higher speeds 8-)stween wrote: 23 Apr 2021 13:53 Okay, sure. I read this as: 1st, 3rd, and 4th jumpers.; I'll give it a shot this weekend. I had hoped to see straight 100%s before doing it, hence my question :)
stween
Alright; for sure the fast ROM works! The system is scoring only a couple of percentage points below yours on the wait states page. Are little differences like these typical on otherwise clean machines? Is there a lot of variation in the RAM in these machines?
It looks like RAM access is 5% slower than it should be, but we really don't know what differences those early machines had...stween wrote: 23 Apr 2021 21:21 Alright; for sure the fast ROM works! The system is scoring only a couple of percentage points below yours on the wait states page. Are little differences like these typical on otherwise clean machines? Is there a lot of variation in the RAM in these machines?
@stween Could you post a screenshot of your RAM card? I'm thinking it might have high latency chips.
Users browsing this forum: ClaudeBot, semrush [bot] and 31 guests
