nice !
:excited: :yay: :bravo:
So next ... 64 MHz ?! :D
CURRENT PROTOTYPE STATUS (SEC 64MHz 68000)
rpineau
Re: V2.5 BOOSTER CURRENT PROTOTYPE STATUS
I need to find faster oscillators next :roll: only one I have is 75Mhz now.. And it does not even try to reset :(... Really need to find something like 55MHz , 60Mhz, 65Mhz.. or something like that..
rpineau
Ok.
You need to beat us .. we've done 50MHz 68030 on our board.. so you are at 50MHz .. time to go higher :)
troed
If only shipping was faster ... I still have three 64MHz 5V ones from my doubleST stuff. Not the square DIL-8 version though, but DIL-14
Actually the seller I bought from still have them, EU, fast shipping: https://www.ebay.com/itm/4x-64-MHz-Crys ... 4ad908842d
Thanks, I found a 64MHz just :D Though the CPU doesn't boot.. So likely around 50MHz is the limit.. maybe 55Mhz if there was such a thing..troed wrote: 29 May 2018 22:27 If only shipping was faster ... I still have three 64MHz 5V ones from my doubleST stuff. Not the square DIL-8 version though, but DIL-14
Will try 52MHz then ;) Having problems finding any oscs at all , mouser all seem out of stock of everything :roll:rpineau wrote: 29 May 2018 22:24 Ok.
Actually my Falcon RSO modules start from about 50Mhz I think.. So will grab one of those tomorrow then I can go up in 1MHz steps easily :)
Atarian Computing
That's crazy. Well done! In terms of integer division, how would a 50mhz 68000 compare to TT's 32mhz 030?
Brilliant work indeed. It’s like breaking the sound barrier :D
Well 030 has a cache so will be faster for the same clock speed, plus 030 is more efficient core.. you would have to benchmark it with GB6 and see what it outputs with and without caches enabled.. Which would be useful anyway as we don't have a TT benchmark vs stock ST.. or Falcon in fact..Atarian Computing wrote: 30 May 2018 04:27 That's crazy. Well done! In terms of integer division, how would a 50mhz 68000 compare to TT's 32mhz 030?
Fantastic job!
:bravo: :cheers:
:bravo: :cheers:
