Those two statements seem contradictory.Saying that.. It might not bus error on TTram..
*Aah* sorry -- I was talking about bus errors so assumed you were too when you said YAARTTT will error at 2000000.exxos wrote: 09 Apr 2021 22:35 YAARTTT will error as the data is wrong (Assume regardless of BERR). If EMUTOS is only checking for bus error then it would find all the RAM.
I've not looked at EMUTOS code, but probably its detection and isolation of "bad RAM" needs a bit of work. It would probably make a good feature and it's how TOS works as well.
Yes. Needs a special build to disable it on the ROM version, but the stock PRG version (not the prior one) won't install it if TOS hasn't already.exxos wrote: 10 Apr 2021 13:02 Ah cool thanks @Badwolf not at home until tomorrow night now :( do you know if altram can be disabled totally? As the fastram.prg installs it anyway, probably won't play nice with emutos anyway :roll:
I keep telling people to use EmuTOS but they want the nicer icons of 2.06. :) Which i asked you to put in EmuTOS like back in 2012 :PBlankVector wrote: 12 Apr 2021 09:18 Hehe, good job :D
Indeed, that's fast.
As you see, a hacked EmuTOS is ideal to run on a hacked hardware.
