PLCC to DIP adaptor - TF536 on A600
culexus
Re: PLCC to DIP adaptor - TF536 on A600
Done some testing to day but I think I got the wrong firmware, I can boot diagrom fine but kickstart 2.05-3.1 is giving me graphical errors but boots, 3.1.4 I get No boot at all just Black screen. Anyone got a link to the firmware that do work? I did test my tf536 in my A500 and it is working just fine.
alenppc
- Moderator Team
I already posted that 3.1.4 doesn’t work with the 536 on the A600.
culexus
Yeah I see that now, sorry for that.
I do get it to boot 3.1 but all the moving graphics is just wrong color and is shaky. Could it be that im using the wrong firmware.?
I downloaded it from github "tf536r2_main_top_test.jed" when I open it in edit I see a date Sun Apr 5 16:58:51 2020.
As I have read it should be the correct one.
alenppc
- Moderator Team
I am not sure which one is that but I posted in the firmware thread the latest one that boots on the A600, however the board doesn’t really work that well on the 600 in general.
For me it kills the floppy drive. So probably not the best solution for that machine.
Lemaru
I'm sure I tested my floppy drive, and it was working fine on mine. Can't remember for sure though so will have to try it again.
I did at one point have everything tinted in a certain colour and artifacts on moving objects. Turned out it was the CPU. Swapped it out and all was good
culexus
Aha :) I do have some more CPU's on the way from china heh.. to test out.
Do you use the CDIS jumper on the board JP5 or the MMUDIS JP3 ?
Methanoid
Lemaru published his... https://github.com/LemaruXPhilC wrote: 13 Aug 2020 08:29 Nice project. Would you be willing to share the pcb files? It may be of some use in getting the TF536 wirking in an Atari STe.
I'd be interested if you can work up an adapter because it should also enable Buffy and PiStorm potentially ;)
Users browsing this forum: ClaudeBot and 16 guests
