PAK68/3-020 40Mhz ...
PAK68/3-020 40Mhz
frank.lukas
PAK68/3-020 40Mhz
Darklord
Re: PAK68/3-020 40Mhz
Frank, I apologize but I'm a bit confused here.
What were you comparing the '020 version of
the Pak board against?
Thanks.
Thanks.
I don't get it either, with NVDI installed it's like 20% slower ?!
Oh different resolutions... the benchmark doesn't really mean anything unless it's compared to a stock machine..Realistically for everyone's sanity, medium resolution should just be used for all tests..
qq1975b
All mad as hatters. :lol:exxos wrote: 08 Apr 2021 19:47 I don't get it either, with NVDI installed its like 20% slower ?!
Oh different resolutions... the benchmark doesn't really mean anything unless its compared to a stock machine..Realistically for everyones sanity, medium resolution should just be used for all tests..
frank.lukas
There is no NVDI !
With the Nova Driver you can use NVDI only as GDOS ...
Your screenshot shows your running version 5.03... ?
frank.lukas
Yes but only as GDOS ...
NVDI set only the cookie. NVDI works with the *.sys driver disable in the gemsys folder only as GDOS.
Users browsing this forum: ClaudeBot and 12 guests
