Re: REV 3 - The beginning
You need slow, keepio and change keeper to float
terriblefire wrote: Tue Apr 06, 2021 10:30 pm You need slow, keepio and change keeper to float
Done that, made no odds.
exxos wrote: Tue Apr 06, 2021 10:37 pm
Well dunno. i never had issues with ram on the ST... worked fine. :)
terriblefire wrote: Tue Apr 06, 2021 10:39 pm Well dunno. i never had issues with ram on the ST... worked fine. :)
No hope for me then :) only works if I invert the RAM clock.. TTRAM does drop a bit in speed, 903% to 847% or something like that.
exxos wrote: Tue Apr 06, 2021 10:42 pm
is your ram clock set to 100Mhz, 50mhz or CPU clock speed...
terriblefire wrote: Tue Apr 06, 2021 10:46 pm is your ram clock set to 100Mhz, 50mhz or CPU clock speed...
CPU CLK50M, RAM ~CLK100M
Current scores...
exxos wrote: Tue Apr 06, 2021 10:50 pm
Hmmm. Yeah leave it like that if its working then... i think later boards i have CPU and RAM at same clock rate.
terriblefire wrote: Tue Apr 06, 2021 10:58 pm Hmmm. Yeah leave it like that if its working then... i think later boards i have CPU and RAM at same clock rate.
Looks like 847% is the "proper" speed anyway... Mine must have been running too fast for some reason to get 903% originally.
https://www.exxosforum.co.uk/forum/viewt ... 975#p42329
exxos wrote: Tue Apr 06, 2021 10:04 pm Finally looking how things are supposed to be :thumbup:
When high it is either accessing ROM or TTRAM... If it is pulsing low, it is accessing the ST bus.. which is not all that often now :)
Yes! That's *got* to be the tipping point.
Should not have been seeing all those AS30s on the ST side.
:dualthumbup:
