Stuff and Things.
PaulJ
Re: Stuff and Things.
Post by PaulJ »
rubber_jonnie wrote: 04 Apr 2021 10:15 Well, back in the day (80's & 90's), I couldn't afford a phone line, so never got on line to experience the fun of BBSes.
I decided this weekend would be a good chance to see what I missed out on back then, so have connected to and joined both ST Guild and
So Jon, do you actually have to connect with a modem or is it a telnet/ssh connection these days. What do they have on bbs’s these days?
PaulJ wrote: 05 Apr 2021 14:59
So Jon, do you actually have to connect with a modem or is it a telnet/ssh connection these days. What do they have on bbs’s thes days?
There are games, competitions in the case of Darkforce, and even ways to contact other users, so what you'd class as email. It's all what you'd perhaps call 'Lo-Fi', but a bit of fun.
Once I am able to get my ST stuff set up again, I may well try connecting using a WiFi modem setup using a real machine, but for now I'm connecting using my Mac and a telnet client.
PaulJ
Post by PaulJ »
@rubber_jonnie , thought I would check it out but you can't get there from here. where is dark force dark force located?
 5  0.csi1.bstnmafr-mse01-bb-su1.alter.net (140.222.10.32)  10.941 ms
    0.csi1.cmbrmabe-mse01-bb-su1.alter.net (140.222.10.38)  9.300 ms
    0.csi1.bstnmafr-mse01-bb-su1.alter.net (140.222.10.32)  10.810 ms
 6  * * *
 7  0.ae4.br2.nyc4.alter.net (140.222.1.61)  9.514 ms
    0.ae2.br2.nyc4.alter.net (140.222.229.93)  9.476 ms  9.447 ms
 8  verizon-com.customer.alter.net (152.179.72.42)  8.784 ms  9.389 ms  8.511 ms
 9  ae-2.r21.nwrknj03.us.bb.gin.ntt.net (129.250.6.96)  10.221 ms  9.141 ms  9.908 ms
10  ae-3.r25.asbnva02.us.bb.gin.ntt.net (129.250.6.116)  14.960 ms  15.400 ms  17.883 ms
11  ae-1.r24.asbnva02.us.bb.gin.ntt.net (129.250.2.37)  14.687 ms  15.733 ms  15.179 ms
12  ae-1.r23.miamfl02.us.bb.gin.ntt.net (129.250.2.87)  36.593 ms  34.329 ms  35.479 ms
13  ae-8.a00.miamfl02.us.bb.gin.ntt.net (129.250.3.41)  38.268 ms  35.395 ms  35.245 ms
14  xe-0-0-47-2.a00.miamfl02.bboi.net (157.238.179.114)  34.958 ms  35.730 ms  34.559 ms
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
@PaulJ Darkforce is at telnet://darkforce-bbs.dyndns.org:520
Sorry I should have said it's on telnet but a different port. ST Guild is standard telnet.
PaulJ
Post by PaulJ »
rubber_jonnie wrote: 05 Apr 2021 19:14 @PaulJ Darkforce is at telnet://darkforce-bbs.dyndns.org:520
Hmm, I used the darkforce-bbs.dyndns.org from his webpage and there was no port specification on his telnet definition.
@PaulJ I had to do a little digging to find the port, but can connect fine now.
PaulJ
Post by PaulJ »
rubber_jonnie wrote: 05 Apr 2021 20:36 @PaulJ I had to do a little digging to find the port, but can connect fine now.
Still hangs here Jon. Say after a minute "Unable to connect to remote host".
PaulJ wrote: 05 Apr 2021 21:07
I was just logged on so I know it's working. You are using telnet and not ssh?
Have you tried: Stguild-bbs.ddns.net
That has no fancy ports and I was also just connected there, just telnet again.
PaulJ
Post by PaulJ »
Yes, was using telnet, tried a ping with no response.. maybe a mega doesn’t even do ping? Also traceroute doesn’t get there either so I’ll chalk the experience up to the opportunity to build telnet on the new machine. It was more a novelty to check it out anyway so not a great loss. I use telnet quite a bit and hadn’t bothered to install it yet.
PaulJ wrote: 06 Apr 2021 14:40 Yes, was using telnet, tried a ping with no response.. maybe a mega doesn’t even do ping? Also traceroute doesn’t get there either so I’ll chalk the experience up to the opportunity to build telnet on the new machine. It was more a novelty to check it out anyway so not a great lost. I use telnet quite a bit and hadn’t bothered to install it yet.
Weird, works fine on my Mac, what machine did you try on?
Users browsing this forum: apple [bot], ClaudeBot and 21 guests
