[SOLVED] STBook TOS wanted
Robson
Post by Robson »
Hi,
Looking for 100% working ENG and GER TOS for STBook.
It seems that the ones I have on file are not working.
(Note: The ones I have are from simbo (Atari forum - ages ago) so those are not good as it seems. This is why I'm asking 100% working ones.)
I have a 2.08 FRA dump that works, but I need the other 2 languages.
Thanks.
Robson
Robson
Re: STBook TOS wanted
Post by Robson »
Update. It seems that I have the correct files but the CRC is not fixed on them so giving me a warning during boot.
Can anyone help me with that? I don't need to split the rom, only to fix it.
Thanks.
czietz
Post by czietz »
The CRC check is slightly different in STBook TOS than in other TOS version. Thus, I think that the usual software for fixing CRC will fail here. Fortunately, I can write (or rather adapt) my own "CRC fixer" easily. I sent you an email with fixed TOS 2.08 ROM images.
Robson
Post by Robson »
Thanks.
I test them and make them available if all good.
Robson
Re: [SOLVED] STBook TOS wanted
Post by Robson »
Thanks to @czietz the files I have are now fixed. I can confirm that the German is working, no error message comes up during boot. I haven't had the chance to test the US one but I'd assume it works as well.
Also added the French to the zip that saved from my French STBook and labelled as 2.08
File attached.
208_Fixed.zip
(468.82 KiB) Downloaded 111 times
Maybe send them over to the tos site ?
http://www.avtandil.narod.ru/tose.html
Robson
Post by Robson »
exxos wrote: Sun Apr 04, 2021 4:46 pm Maybe send them over to the tos site ?
emailed. thanks.
