TF536 Firmare Update RC3
68030 + SDRAM + IDE
PaulJ_2.0
Re: TF536 Firmare Update RC3
Post by PaulJ_2.0 »
For people in the UK that have purchased cards internationally and don't want to deal with customs fees, I offer a fast and free (you pay postage) flashing service.
Unless you smacktalk Stephen, then it's gonna cost ££££
PM me please, don't litter this thread.
matt020
Post by matt020 »
@terriblefire Now with the knowledge of what the problem was, is it only likely to cause lock ups when using the TF536 IDE? I am using a Buddha IDE card and if I don't have to send it off for reflashing, I won't.
Thank you,
Matt.
theq
Post by theq »
Have been vigorously testing this on my A500 rev. 6, A500+ and A1000 without any issues.
Great work, and thank you!
Edit: And on my Nth copying from folder -> RAM: -> folder it started going in slow motion. Floppy clicks from everything between 6 to 12 seconds. But it didn't hang, though. Just took longer time.
(Happened when RAM-disk was almost full, so might be something unrelated)
alenppc
Moderator Team
Moderator Team
Post by alenppc »
matt020 wrote: 01 Apr 2021 12:18 @terriblefire Now with the knowledge of what the problem was, is it only likely to cause lock ups when using the TF536 IDE? I am using a Buddha IDE card and if I don't have to send it off for reflashing, I wont.
Thank you,
Matt.
Yes, this won't make any difference for Buddha, it is 536 IDE only.
lopezpb
Post by lopezpb »
There are two files r1 and r2 in the zip file, do I understand correctly that r2 is for reversion 2b card?
lopezpb wrote: 01 Apr 2021 13:13 There are two files r1 and r2 in the zip file, do I understand correctly that r2 is for reversion 2b card?
Flash the one thats for your revision of the board. There arent many rev1s out there
dalek
Post by dalek »
Flashed my rev 1 no issues. Is there a better test case than just copying files indefinitely?
dalek wrote: 01 Apr 2021 13:46 Flashed my rev 1 no issues. Is there a better test case than just copying files indefinitely?
Nah its pretty boring. I'd asked @Daedalus to write me an arexx script to keep Dopus doing stuff but after i got the issue to reproduce in a unit test i figured we're good.
LIV2
Post by LIV2 »
amimjf wrote: 31 Mar 2021 20:33 Hi does this resolve just the INT2 / DTACK issue ?, or is there anything else.
What is the INT2/DTACK issue?
:edit: nevermind I see it mentioned in the other thread specific to write issues
dalek wrote: 01 Apr 2021 04:05 :thanksyellow: will flash as soon as I can :cheer:
The police will pick you up for that.. better not to.
Return to “TF536”
