Wanted - joystick ports from STFM or E keyboard
friijy2001
Post by friijy2001 »
As my STE had a run in with the delivery man the plastic around the ports on the keyboard has broken so am after anyone who has the circuit board from a damaged ST that is could plunder these parts from. If you can help me out that would be great :)
Call me Stephen :)
Re: Wanted - joystick ports from STFM or E keyboard
Not sure what plastic parts you are referring to ?
I’m guessing that he means the DB9 port itself is damaged.
friijy2001
exxos wrote: Sun Mar 28, 2021 10:54 pm Not sure what plastic parts you are referring to ?
I should of posted a picture before, I will remember next time.
It's a good job I did not call it that thingy, under the thing on the keyboard!
As you can see the plastic is damaged, still works and functions but was thinking it would be good to replace if i can :)
Call me Stephen :)
DoG
Post by DoG »
9-port dsub for PCB is still very common so you could probably get one new. Or are they special in any way?
friijy2001
I’ll take a look thank you :)
Call me Stephen :)
