If you open up your keyboard and see dark spots on your keyboard traces, chances are moisture has gotten through the green keyboard lacquer and your traces have started to rot. Just repaired some traces today on a keyboard and took some photos:
Example of dark spots on traces
Example of traces that can be 'touched up' with solder to stop further corrosion. Rub down, add flux and run solder over. Then re-seal.
This area has copper that has completely been eaten away
Sand it down, run flux and solder over and start laying wire
Wire laying finished
Spray with pcb lacquer
Repairing traces on an ST keyboard
Re: Repairing traces on an ST keyboard
Looks really nice. Much cleaner then a keyboard repair I did.
Cheers
Yours was a bit more extreme of damage tho! hehe
For light corrosion I find that a fibreglass pen is excellent for cleaning up with minimal damage and you can either just re-lacquer or solder as you've done, depending on the amount of corrosion.
Just don't touch the end of the pen or you get nasty bloody fibres in your finger!!
Needs at least 100 more exclamation marks!rubber_jonnie wrote: Mon Feb 15, 2021 3:32 pm Just don't touch the end of the pen or you get nasty bloody fibres in your finger!!
@Steve be careful the wire doesn't interfere with the rubber cup as it sits down..
@DoG just did a repair in the same place as yours lol, must be a popular place to punch an ST
Push the broken part back in to place with a little force, strengthen with some glue. Scrape away the lacquer, check continuity Add flux and go over with solder. Add new wire and solder to trace Finish by spraying with new pcb lacquer Rear side has had glue absorbed into the cracks for strength
Yup, I have to agreeexxos wrote: Mon Feb 15, 2021 3:51 pmNeeds at least 100 more exclamation marks!rubber_jonnie wrote: Mon Feb 15, 2021 3:32 pm Just don't touch the end of the pen or you get nasty bloody fibres in your finger!!![]()
