Paradroid STE DMA issue blog
Re: Paradroid STE DMA issue blog
mst wrote: 07 Feb 2021 13:07
Steve wrote: 07 Feb 2021 12:51 @mst
Here is my testing today with the STE & new firmware. So far the new firmware is /more stable/ than the original with this particular system, but is not as stable as an ultrasatan (fails copy test) and Jookies program still fills the screen with X's which I think is failed writes. But it seems no MBR corruption, where as original firmware did have MBR corruption.
Thank you so much,
The STEs equipped with -38 DMA chip are really annoying; these will need to follow all Exxos research and fixing stages...
Yes - this particular STE has had all the fixes. But interestingly it is an early motherboard with several bodge wires and fixes on top of the motherboard. Same as @geogeo_28 's in fact, who also is struggling with his Ultrasatan. I think these bodge wires and early fixes could be causing some kind of noise.
See here:
@Steve didn't the ultrasatan fail on a H5 though ? That would imply ultrasatan has a fault as the H5 has very little noise and all the fixes built on..
mst
Post by mst »
Steve wrote: 07 Feb 2021 13:13
Thank you so much,
Yes, these airwires need shielding, at least.
My mobo, from 1990 has two airwires too; obviously without shielding... and airwires do not make me or anyone happy
exxos wrote: 07 Feb 2021 13:15 @Steve didn't the ultrasatan fail on a H5 though ? That would imply ultrasatan has a fault as the H5 has very little noise and all the fixes built on..
No that was the ASCI2STM. I have also just run some testing on my TT @mst :
TT:
ULTRASATAN:
RUN HDTEST - Lots of X's
WRITE DESKTOP.INF - PASS
COPY GAME TO C:\ - PASS
ASCI2STM: ORIGINAL FIRMWARE
TT
Nothing, 4 bombs on boot
ASCI2STM: NEW FIRMWARE
TT
Boots, but no drives detected
So at the moment.. of course this has just turned into an ASCI2STM testing round. It seems there is a lot of work to be done on the ASCI2STM firmware.
So can ultrasatan be tried on a H5 ?
exxos wrote: 07 Feb 2021 13:38 So can ultrasatan be tried on a H5 ?
I'll try right now... give me a few minutes
Steve wrote: 07 Feb 2021 13:41 I'll try right now... give me a few minutes
:thumbup: :ball:
ULTRASATAN & H5
@exxos
H5 (DMA 38- 9H1 61):
ULTRASATAN:
COPY GAME TO C:\ - FAIL, copy dialogue just 'dissapears' without copying anything, MBR OK
ASCI2STM NEW FIRMWARE & H5
@mst
WRITE DESKTOP.INF - FAIL, 'this disk does not have enough room'
Steve wrote: 07 Feb 2021 14:22 ULTRASATAN & H5
@exxos
ULTRASATAN:
When I get home tonight I'll try my ultrasatan and see if the program behaves. If it does, then if the one you have the external grey box type ? If so, take some images of the PCB then we can compare it to mine (assuming it works ) then we can see if the ultrasatan itself has changed somehow..
Users browsing this forum: ClaudeBot and 15 guests
