I mean, it says "terrible fire" right on itgo0se wrote: Thu Jan 21, 2021 8:53 pmWhere's your sense of adventure??8 Bit Dreams wrote: Thu Jan 21, 2021 8:20 pm Wow! Hopefully You was prepared to see fireworks on power on, since these are four-layer boards. Cutting them may short out GND and VCC inner layers..![]()
My first TF536
Re: My first TF536
Re: My first TF536
Seriously though. There are no traces there, just ground and voltage planes, and they are easy to see at the cut edge. I will put a piece of kapton tape over the edge before I install the RF shield so that there's no chance the shield will touch the layers at the edge.
Re: My first TF536
I built an IDE68k today for my A2000 and tried it in my A500+ first. Booting from SD is much quicker than with TF534 or 536. I built this: https://www.pcbway.com/project/sharepro ... plica.html
Booting to WB with CF with my TF536 takes 17 seconds, which is pretty quick. I'll time the IDE68k later...
IDE68k boots to WB in 13 seconds. The same image takes over 40 seconds with my TF536 (one of the slow booting cards. See next post).
Re: My first TF536
BTW. Different SDcards take different times to boot even if they have the exact same image on them. What's doing that? With some SD cards I try it takes 20 seconds for it to start doing anything (led activity) while others are instant. Repeatable even when I reinstall freshly to the different cards. Same maxtransfer setting. I have done a huge amount of comparisons. KS3.1 There's more to SD cards than we have control over.
I'm gonna sell my A500 with one of my TF534 now that I have the 500+ and to make the user experience as good as possible I tried all my SD Cards lol and ended up with a 2 GB card that boots in 20 seconds with full WHDLoad and patches.
Maximilian
Re: My first TF536
Could you share the manufacturer, type and size of that one?Lynxman wrote: Sat Jan 23, 2021 3:07 am I tried all my SD Cards lol and ended up with a 2 GB card that boots in 20 seconds with full WHDLoad and patches.
I would be interested to know what makes that one so special.
Re: My first TF536
I was more wondering how it works, do they not conflict?Lynxman wrote: Wed Jan 20, 2021 6:02 pm Yes. I originally built that red RAM expansion for my A500, and when I got this A500+ I moved it over the the A500+ because it has room for another ram chip to give 1 MB extra chip ram. I then put another old school expansion that only could have 512 kB in my old A500. I omitted the motherboard battery because of the clock on the ram board and it seems to work fine. It's more practical to have battery access from the expansion bay anyway.
Have you disabled the onboard RTC?
Re: My first TF536
It's an old Sandisk with a strange sticker on it saying "Easy Going". I don't remember what it came in. Probably an old GPS. It has SanDisk stamped in the back which is how I know it's Sandisk. I have another Sandisk Extreme III 2GB which has higher transfer speeds but still bootsmuch slower. It takes 20 seconds before any activity happens with it. There's something in these things causing them to act differently.Maximilian wrote: Sat Jan 23, 2021 5:00 amCould you share the manufacturer, type and size of that one?Lynxman wrote: Sat Jan 23, 2021 3:07 am I tried all my SD Cards lol and ended up with a 2 GB card that boots in 20 seconds with full WHDLoad and patches.
I have ordered a different IDE to SD adapter which was more expensive which might change things too.
Maximilian
Re: My first TF536
For the PC I modded some CF adapters a long time ago to enable PIO 4 etc., that made a lot of difference.
Re: My first TF536
Not sure. I haven't paid much attention to the clock. Guess it would be a good idea to disable the one on the expansion.PaulJ_2.0 wrote: Sat Jan 23, 2021 11:46 amI was more wondering how it works, do they not conflict?Lynxman wrote: Wed Jan 20, 2021 6:02 pm Yes. I originally built that red RAM expansion for my A500, and when I got this A500+ I moved it over the the A500+ because it has room for another ram chip to give 1 MB extra chip ram. I then put another old school expansion that only could have 512 kB in my old A500. I omitted the motherboard battery because of the clock on the ram board and it seems to work fine. It's more practical to have battery access from the expansion bay anyway.
Re: My first TF536
What's involved in that mod?Maximilian wrote: Sat Jan 23, 2021 5:09 pm For the PC I modded some CF adapters a long time ago to enable PIO 4 etc., that made a lot of difference.
