I have a feeling this poor drive has seen better days, it makes sounds like it's trying to dial-up to SCSI heaven:
Although it did show up as detected once, I haven't able to get it detected again since:
C-Lab MK2 CA401332-002-REVC / Repair/Restore log
Re: C-Lab MK2 CA401332-002-REVC / Repair/Restore log
wow, is the motor actually running ? Kinda sounds like its stuck.Steve wrote: 12 Jan 2021 16:18 I have a feeling this poor drive has seen better days, it makes sounds like it's trying to dial-up to SCSI heaven:
It is spinning... just sounds like a dial-up modem when it tries to read.
It looks like someone has had it open, given the broken warranty seal.
MegaSTEarian
Sounds painful :shock:
Hope the customer hasn't got any data in there.
On another note, how easy is to source an HDD like this?
I think old small 2.5'' scsi's like this would be hard to find. My customer should have his data backed up to tape so hats good.
I'll be recapping the PSU and motherboard next, I'll post photos when I get to it.
BIG UPDATE ON PROGRESS
* Openflops drive installed
* NVRAM replaced
* FPU installed
* Recapped PSU
* Recapped Mobo
* SCSI Terminator installed
* Wait states disabled to increase TOS speed
* Silence fan by wiring to 5v instead of 12, clean dust.
RECAP POWER SECTION
~ BEFORE ~ AFTER RECAP AUDIO SECTION
~ BEFORE ~ AFTER Using top-quality Nichicon audio-grade golden caps RECAP MODULATOR SECTION
~ BEFORE ~ AFTER Note: the 470uf C24 cap is installed the / CORRECT / way, as it is marked incorrectly on board/schematics MAKE UP 4700UF MAIN CAP SILENCE FAN BY WIRING TO 5v & CLEAN DUST ADD INTERNAL SCSI TERMINATOR (So external drives still work without internal drive) INSTALL EXXOS NVRAM NVRAM FINISHED & CAN SEE NEW FPU IN BACKGROUND PUT TOGETHER FLASH FLOPPY DRIVE ~ TEST DRIVE INSTALL NEW CF CARD MOBO FINISHED BEFORE RE-ASSEMBLY TESTING BEFORE CASE FITTING CLEANING
Cleaned and disinfected with 99% IPA & Keyboard vacuumed of any dust
* NVRAM replaced
* FPU installed
* Recapped PSU
* Recapped Mobo
RECAP POWER SECTION
WAITSTATES DISABLED FOR FASTER TOS SPEED
PSU RE-CAP
Assume you replaced the ROM ? The original ROM will bottle out after a few hours normally.
I checked and this rom has the exact same serial number as the one in your store, so I think it is a fast rom (assuming serial number is a factor) I will of course run benchmarks and tests in the next few days.exxos wrote: 22 Jan 2021 20:20 Assume you replaced the ROM ? The original ROM will bottle out after a few hours normally.
@exxos check the fan silencing photo, you can see the ROM there.
Users browsing this forum: ClaudeBot, semrush [bot], Steve and 12 guests
