Atari TT - FPU Overclock
Re: Atari TT - FPU Overclock
Ah thanks for going to all the trouble of checking :) I am guessing that an overclocked FPU might help speed up some tasks in Netbsd since an FPU is required for that OS, I wonder what software use it or whether they just require an FPU as the base requirements for all possible types of calculations.
Hi Icky, today I finally got around to making this little overclocker for my TT FPU. I used a 48mhz Osc. Thanks again for the instructions, I have before/after benchmarks below:
My version:
Before results:
Nembench -
Fractals (run in TT Medium 16 colour mode) -
Gembench -
After results:
Nembench -
Gembench -
@Steve - nice :thumbup:
Reminds me I have to do this to the TT I am restoring / upgrading.
mrbombermillzy
Post by mrbombermillzy »
Hey, I just wondered if any of you guys actually tried running up the FPU past 48Mhz? Does the IC run hot at 48?
(As an aside, I did some FPU tests a while ago and if the chip can run 64Mhz (or more!) then there may be a possibility for it actually being useful for non FPU tasks (extended MOVEs instead of or interleaved with the 030).
mrbombermillzy wrote: 18 Jan 2021 20:53 Hey, I just wondered if any of you guys actually tried running up the FPU past 48Mhz? Does the IC run hot at 48?
https://www.exxosforum.co.uk/atari/last/FPU/index.htm
mrbombermillzy
Thanks Chris.
So, thats up to 64Mhz stable really and with no added cooling? Interesting.
I wonder what a HS and even a fan could do for that figure?
mrbombermillzy wrote: 18 Jan 2021 21:14 So, thats up to 64Mhz stable really and with no added cooling? Interesting.
Yep... I don't think any cooling will help, I don't think it got hot even, but cant say exactly as was some years ago now.
mrbombermillzy wrote: 18 Jan 2021 21:14 Thanks Chris.
Yes but notice the times:
32mhz MB clock - 46.115 seconds
50mhz oscillator - 44.98 seconds
64mhz oscillator - 44.70 seconds
No point running at just-about-to-crash-and-burn 64mhz speed, when it only gives a tiny increase in speed, see the diminishing returns? So this is why people are using 48mhz as it is the safest and quickest before diminishing returns.
The tests were on the falcon with 16mhz bus. If the bus fas faster then a higher clock speed may be benifitial.. But it does start to get a bit pointless past 50mhz otherwise.
mrbombermillzy
I was actually looking at the viability on a TT. And even then, in a very non standard way.
Users browsing this forum: ClaudeBot, gpt [bot], Icky, nicknm and 15 guests
