Tony and his vanishing drive partitions.
Re: Tony and his vanishing drive partitions.
rubber_jonnie wrote: 18 Jan 2021 13:26 Easus is good, but for SD cards Win32DiskImager is my weapon of choice :)
Simple to use, one shot image of the whole card.
cool, will download that, I like simple ;)
Cosmic Puppet
Post by Cosmic Puppet »
exxos wrote: 18 Jan 2021 13:15 I started using this one to backup with https://www.easeus.com/backup-software/tb-free.html
I'm finding the one that comes with windows okay:
The clone feature looks interesting but isn't free. I already have to buy this: https://www.aomeitech.com/aomei-partiti ... stant.html
I've ended up with a stupid drive and need to leap frog partitions to consolidate it as I'm running out of space.
Need to join the end partition with C: Short stroking my drive seemed like a good idea at the time. Now it's a mess!
As described here:
The merge feature isn't free as described though.
If I was rich I'd employ an I.T. God. :lol:
Cosmic Puppet
I've just confirmed that I have the latest Driver for the UltraSatan.
Peter thinks it's a windows 10 issue.
I've had windows not see hardware after a past update, so we know it can muck things up.
I'll just be religous about backing up.
@Cosmic Puppet Have you considered not using so many partitions? Rather than having 14 512mb TOS partitions, try having 1-4 512mb's and then one large FAT32 partition? You just need Bigdos driver in AUTO to be able to use it.
Cosmic Puppet
Steve wrote: 18 Jan 2021 14:39 @Cosmic Puppet Have you considered not using so many partitions? Rather than having 14 512mb TOS partitions, try having 1-4 512mb's and then one large FAT32 partition? You just need Bigdos driver in AUTO to be able to use it.
512 is the max for any single partition for the STFM using TOS 1.04 I believe.
They are quite full. I could drop 2 drives that I'm not currently needing next time I have to redo it.
Having the drives like this also makes it easy to access games.
I'm pretty sure with the bigdos driver you can have up to something like 2gb. Unless I'm just completely wrong :)
Cosmic Puppet
Steve wrote: 18 Jan 2021 17:49 I'm pretty sure with the bigdos driver you can have up to something like 2gb. Unless I'm just completely wrong :)
How do I get bigdos? The guy in the video says TOS can't address more than 512MB.
I could be told anything and be none the wiser. :lol:
http://rainer-seitel.onlinehome.de/bigdos.html
Though think there may be a typo on that page..
@Cosmic Puppet Just in case you're wondering why the PP driver isn't listed on the Bigdos page Exxos linked, it's because the PP driver was only written in the last few years. It should still work but to be sure you just need to try it. It's as simple as putting Bigdos.prg in the AUTO folder, and of course having a FAT32 partition to try it with. I've always used it without issue, but I use HD Driver.
Cosmic Puppet
I don't know what to do next. Everything looks the same.
Users browsing this forum: ClaudeBot and 27 guests
