Hello y’all! Recently acquired a Falcon and although it’s working fine at the moment I want to give it a recap and look into ways on how to improve its longevity. It’s a German system with 14 MB of RAM from the factory.
Motherboard number shows CA401332-003 Rev-B.
Went ahead and took it apart. I have no idea how a Falcon motherboard is supposed to look so please let me know if any previous modification has been made by past owners. There seems to be a resistor soldered to the floppy DMA chip(?) for instance. HDD has been replaced obviously.
It should be safe for me to install the buffer patch as the RTC area seems pretty untouched? Apart from the RTC itself which has been replaced together with a new socket.
So I’m about to order new capacitors and would like to hear some thoughts first. Should I use caps with higher voltage ratings than the originals? I also read something about replacing electrolytic caps with lower values with polyester film caps instead, is this a good idea?
The caps on the PSU might have been replaced at some time, it looks like it.
Falcon recap and overall maintenance
harbert
Re: Falcon recap and overall maintenance
Hi there,
Your Falcon currently has a very basic clock patch fitted, that resistor you mentioned on the SDMA. If you wanted to replace that with Exxos clock patch for instance you would need to remove that resistor and patch the SDMA trace back, quite easy to do with some practice. I would only recommend doing this if you tested the machine and it showed some kind of instability or sound issues though.
In regards to poly caps, you can use them but only for the 1uf caps to be honest, as anything larger becomes too physically big. (I did use a few 1uf polys in mine) No need to go for higher voltage caps, you can without issue but the stock spec voltages are well above where they need to be anyway. Just make sure they're the same farads.
If you want to go for axial caps like what Atari used, I think the only brand that makes them now is Vishay. Otherwise radials work fine, just not as pretty. Also be aware the ground plane is a real bugger on the Falcon so you'll need plenty of patience and flux. Just don't get frustrated and try to force any caps out.
Here is a list of all Falcon caps if this helps you order new ones:
(List courtesy of Daniel Hedberg)
If you get a chance please upload some high quality motherboard photos to the 'Motherboard revisions' section of the forum, we like to catalogue them for variations etc.
Name Voltage Capacitance Location
C1 16V 22uF Under PSU
C2 25V 4.7uF Under PSU
C6 25V 4.7uF Under PSU
C7 50V 1uF Under PSU
C11 25V 4.7uF Under PSU
C29 16V 100uF Under PSU
C67 16V 47uF Under PSU
C110 16V 100uF Mid section
C147 16V 4700uF Mid section
C181 50V 1uF Mid section
C117 6.3V 220uF Near Floppy cable
C24 35V 470uF Video section
C36 16V 100uF Video section
C48 50V 1uF Video section
- 50V 10uF Video section
C50 16V 100uF Video section
C54 16V 47uF Near SCSI port
C78 50V 2.2uF Near SCSI port
C56 16V 47uF Under Floppy Drive
C57 16V 220uF Under Floppy Drive
C83 16V 47uF Under Floppy Drive
C84 16V 47uF Under Floppy Drive
C88 50V 10uF Under Floppy Drive
C91 50V 10uF Under Floppy Drive
C92 50V 3.3uF Under Floppy Drive
C121 16V 220uF Under Floppy Drive
C127 50V 3.3uF Under Floppy Drive
C138 16V 47uF Under Floppy Drive
C141 50V 10uF Under Floppy Drive
@harbert Could you please upload your images to the forum and not link to external sites , as once those images vanish, it will render this thread useless in the future, thanks.
harbert
Sorry about that Exxos! I wasn’t sure if it would be appreciated or not given that it is several hi-res pictures.
Thank you for such a quick reply Steve! I highly appreciate it! Went with radials when recapping my STE and I’ll probably do the same here as the quality of the caps are more important to me than the overall tidiness of the board.Steve wrote: 16 Jan 2021 20:56If you want to go for axial caps like what Atari used, I think the only brand that makes them now is Vishay. Otherwise radials work fine, just not as pretty. Also be aware the ground plane is a real bugger on the Falcon so you'll need plenty of patience and flux. Just don't get frustrated and try to force any caps out.
Thanks! I think there are some slight differences to my motherboard. I didn’t spot any 6.3V cap on C117 for instance, same farads but 16V.
Higher voltages are fine, and sometimes offer better ESR values. I wouldn't go with lower values than used. higher values may well be OK, but without a huge study of the circuits they are actually used in, it would be a huge undertaking.harbert wrote: 16 Jan 2021 17:52 So I’m about to order new capacitors and would like to hear some thoughts first. Should I use caps with higher voltage ratings than the originals? I also read something about replacing electrolytic caps with lower values with polyester film caps instead, is this a good idea?
Film caps are generally a lot better, but its getting them to physically fit which is the problem. Film caps will increase the transient response times on power rails and reduce hiss in audio circuits etc
@harbert
Here's a shot of my board where you can see which caps can be replaced with the poly caps. As you can see they get quite large and barely fit in some places.
harbert
Thanks for the picture Steve! I think I’ll order film caps for values 3.3uF and lower at least and see if I can get them to fit.
For the 16V 47uF caps, I found Panasonic FR electrolytics that are slightly above in voltage (25V), if I want them to be same as the originals then it seems I have to go with the AK series or something. Panasonic FR 25V 47uF would probably be the better choice here given the lower ESR?
Yes go for FR definitely, higher voltage is fine :)
viking272
Hi Harbert,
Where are you ordering your capacitors from?
I need to do my Falcon motherboard quite soon. Did you get all 28 in Daniel Hedburg's list?
Thanks!
Thanks!
harbert
Hi,
I’ll be getting some of the caps from Farnell through their export site. Seeing that you live in the UK you should have no issue ordering everything you need from their regular site. Others I’ll be getting from a more local Swedish retailer.
I’m planning on replacing all of the electrolytics. Went with Exxos 4,700uF axial replacement kit for the C147. Wrote down some values from my Falcon motherboard and a few of the caps are slightly different to Hedberg’s.
Wishing you good luck recapping your Falcon! :-)
Users browsing this forum: apple [bot], Baidu [Spider], ClaudeBot and 6 guests
