Could be anything, some signals routed under or near the left chip.. bad grounding on the left one.. probably just layout of the pcb, either tracks or physical location..Paulo P wrote: Tue Apr 24, 2018 8:04 pm No, I didn't run memory test software yet... but I have this feeling that the more RAM access, the worse noise is in the audio out. No matter if it is a direct stereo output or monitor audio (pin 1).
So, the question is why and if there is a possibility to defuse this noise and interferences.
And why only in left channel?
Hissing and whistling in the STe audio output
Re: Hissing and whistling in the STe audio output
I understand. So, if you would have time sometime, please record your machine(s) to find out if all machines are the same and the hissing appears there too.exxos wrote: Tue Apr 24, 2018 8:13 pmCould be anything, some signals routed under or near the left chip.. bad grounding on the left one.. probably just layout of the pcb, either tracks or physical location..Paulo P wrote: Tue Apr 24, 2018 8:04 pm No, I didn't run memory test software yet... but I have this feeling that the more RAM access, the worse noise is in the audio out. No matter if it is a direct stereo output or monitor audio (pin 1).
I will try and do that later this week...Paulo P wrote: Tue Apr 24, 2018 8:27 pm I understand. So, if you would have time sometime, please record your machine(s) to find out if all machines are the same and the hissing appears there too.
OK, I hooked up my STE to my PC.. I hear the sounds I think.. but this is PC noise...
Can't seem to record it in audacity... but when I run graphics test, sound goes mental.. I always disable the line input jacks on my sound card because I always hear loads of noises... makes no odds if the STE is plugged in or not..
think it would need a really good quality sound recording device which has low noise ot start with, I don't think PC's are up to it (at least not mine anyway)
OK finally got it recorded..
This is pure PC noise... after 10 seconds I start graphics tests...
If it's any help as a reference, the TT's audio output (twin phono) is a great bus monitor. You can hear all the memory accesses as a twerping "hiss" and it's amplified by the internal pre-amp as if you turn the sound volume down in the control panel the "hiss" decreases also.
I have heard noise on my STE's, but I only used headphones direct. Pressing spacebar pretty much deafened me it was that loud. so any noise I should hear it easily. I did hear a tiny bit, more so on RAM access, but my dac fix solved it, but I could barely hear it to start with.
The interesting thing is that you don't have the peaks at 2600Hz and 15000Hz. Your hiss sounds a little different than mine.exxos wrote: Tue Apr 24, 2018 9:30 pm OK finally got it recorded..
So, the same situation on TT too?stephen_usher wrote: Tue Apr 24, 2018 9:36 pm If it's any help as a reference, the TT's audio output (twin phono) is a great bus monitor. You can hear all the memory accesses as a twerping "hiss" and it's amplified by the internal pre-amp as if you turn the sound volume down in the control panel the "hiss" decreases also.
Did a new sample..
PC only (STE turned off)
STE Turn on.
Samples..
On the STE one, I do hear (and you can hear in the audio) when it starts doing memory test, you can hear the "dashes" on the screen as the come up..
I need to find me headphone adapter and try that again...
STE Turn on.
Samples..
