MegaSTE Repair Continued - Video Noise
geogeo_28
Re: MegaSTE Repair Continued - Video Noise
New picture of the noise:
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Atari Falcon030 (US).
- Amiga 1200 (UK).
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
BTW if that PSU is better, have you tried moving it closer to the motherboard ? Also wondering if the video is picking up interference from the PSU.. and as you have the meanwell "out" of the way... was just a thought anyway..displaced wrote: 07 Jan 2021 00:08 Well, whaddya know...
Wired up a Meanwell RQ85B, and here's the output (earth connected, OSSC powered via its usual USB adapter).
Also the problem may be on the RGB drivers .... May need better caps...
geogeo_28
I replaced all the caps with new ones but I should definitely test them again. I have an Atlas ESR70 to help. I have to check the diodes also.
Is it possible that the floppy controller adds noise on the bus? Definitively, I know that I have issue with this controller and it needs to be replaced.
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
The whole motherboard is a noise generator..
geogeo_28
Unfortunately, switching to another shifter did not solve the problem.
The motherboard has a bigger issue... Keep you posted if I make progress..
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
displaced
I didn’t try this I’m afraid - got caught up in other stuff. But in the meantime, I received one of your recap kits for the MSTE PSU and fitted it. There’s slightly more noise than with the Meanwell, but not enough to be a problem. Could be, as you say, proximity related. Still well within what I get with my other old machines, so I’m happy with it.exxos wrote: 12 Jan 2021 16:22 BTW if that PSU is better, have you tried moving it closer to the motherboard ? Also wondering if the video is picking up interference from the PSU.. and as you have the meanwell "out" of the way... was just a thought anyway..
Got an Epson SMD-340 on the way to go with the AJAX and HD-capable GAL in the machine. Then I just need to wait for the weather to warm up so I can respray the case.
A bunch of Ataris and others:
Atari XEGS with RGB mod - STFM - Portfolio - Lynx Mk1 with McWill display - Mega STE - Falcon030 - Jaguar
Commodore VIC-20 CR with ClearVideo - CDTV (Wicher 8MB+IDE)
Acorn Electron - Archimedes A3020
geogeo_28
@exxos Sorry to revive this topic. By curiosity I saw a post https://www.atari-forum.com/viewtopic.php?t=27647 where you mentioned the possibility to create a buffer for the RGB lines to clean the signal.
Do you have a schematic or could you give more details about this circuit?
Thanks a lot!
Thanks a lot!
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
The project was abandoned a long time ago.. too much noise on the motherboard, and even if you buffer everything and make everything look perfectly fine on the scope, the route across the motherboard will pick up noise anyway. If you want better video you will have to wait for the next batch of H5 motherboards where all these problems have been fixed.geogeo_28 wrote: 11 Apr 2021 20:05 @exxos Sorry to revive this topic. By curiosity I saw a post https://www.atari-forum.com/viewtopic.php?t=27647 where you mentioned the possibility to create a buffer for the RGB lines to clean the signal.
Thanks a lot!
geogeo_28
I guess I will wait for the next batch of H5 motherboards. :)
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
Users browsing this forum: ClaudeBot, simon.osborne and 7 guests
