Noob building a TF534
8 Bit Dreams
- Moderator Team
Re: Noob building a TF534
You've choosed wrong slot,
this one should be occupied by this card:
https://gitlab.com/MHeinrichs/multifix-aga it's also four layers unfortunately.. 🤔
Lynxman
I rendered these on my 50 MHz 534 in the closed up A500. Found the scripts through another thread here. The fish took a little over 3 hours while the teapot was much quicker even though the resolution was higher. I guess this means my 50 MHz 534 is stable inside the A500. :) I haven't used POVray since the early 90's in MS DOS. It's actually what got me started with 3D modelling and today I design and sell 3D models online.
Cosmic Puppet
These are great! :)
Lynxman
But are the middle layers needed for circuitry or just for ground/Vcc planes?8 Bit Dreams wrote: 15 Dec 2020 22:08 You've choosed wrong slot,
8 Bit Dreams
- Moderator Team
Yes, that's normal, rendering without FPU (cpu only) takes about 2.5 hours,
while same set of pictures is done in 30 minutes if FPU is in use. This is very noticeable if You are using such programs like iBrowse for example, however You'll need more than 4MB of ram then...
It'll be a pain in the a** to solder such board without solder mask anyway, and it'll be a nightmare to debug it if something goes wrong..Lynxman wrote: 17 Dec 2020 23:19 But are the middle layers needed for circuitry or just for ground/Vcc planes?
Lynxman
I'm very patient. ;)
It's possible to apply UV solder mask and then route off the pads with a spring V-bit. I actually made a spring V-bit today for that with my lathe. It ensures that only light pressure is applied to the PCB when milling to only remove the relatively soft solder mask. I don't want to mess with solder mask for most things though.
Lynxman
My Amiga 2000 with the 33 MHz TF534 took 3 hours 8 minutes to render the same fish picture. Why would it take the same time at 33 MHz as it did with the 50 MHz A500?
8 Bit Dreams
- Moderator Team
Because floating point calculations is something that FPU, not cpu is supposed to do, there is no huge difference between 33 and 50MHz for cpus in rendering, it sucks in both cases, and it gets really hot when it runs @50MHz, in fact povray - is the best tool to check cpu for failure, most reprinted cpus will fail after 15-20 minutes of testing.
Lynxman
Ok. I will add a FPU to one of them soon just for kicks. I bought one from the Exxos store along with a couple of TF536 PCB's.
Here's a shot of my "renderfarm":
