TF536 Atari firmware
Other boosters or variants.
agranlund
Re: TF536 Atari firmware
Post by agranlund »
czietz wrote: Tue Nov 24, 2020 4:45 pm Sidenote: The Atari / TOS also requires "write allocate" to be active on the 68030 or it will crash sooner or later. I could go into a (long) explanation why this happens, but for now I'm just going to quote the UM: "WRITE ALLOCATE [...] The supervisor should set this bit when it shares data with the user task". I.e., it's required when user and supervisor mode access the same memory locations, which obviously happens during TOS calls.
Thanks! That's enough of an explanation for me :)
czietz wrote: Tue Nov 24, 2020 4:45 pm Either use a cache-aware OS or completely disable the cache.
I'm giving this quote a million thumbs up!
Atarian Computing
Post by Atarian Computing »
I couldn't find any information by searching. Does the TF536 support two IDE devices, i.e. primary and secondary?
Atarian Computing wrote: Tue Dec 01, 2020 11:05 am I couldn't find any information by searching. Does the TF536 support two IDE devices, i.e. primary and secondary?
Thats supported by the master IDE device not the port itself.
e.g. Master slave.
Return to “EVERYTHING ELSE”
