Assembled TF536 - help needed
68030 + SDRAM + IDE
sampedenawa
Post by sampedenawa »
Hello everybody !
I assembled my TF536, but I am having a number issues I was enable to spot correctly.
The board boots, but shows the red "expansion board diagnostic" defective screen (correctly showing manifacture 5080= Stephen, product=2).
If I continue, I can boot from floppy, load WB and run stable for hours, BUT:
- Do not see any fast mem
Additionally, IDE seems to be active, I can select "DH0" device from os 3.1/3.1.4 boot list, but if I try to load wb from IDE, it never comes to end (ide acrivity led continuously blinkin as if it loads from CF, but actually I don't think it does)
I triple checked all solderings with a scope, did not spot any shorts or missing solderings
Memory chips are MT48LC16M16A, so they should be the most compatible.
Would anyone post a close hires pic of the top side of the board I can use as reference ? Maybe I misplaced some IC (i don't think so, but anyway ....)
Anyone has some hint to troubleshoot ?
Thanks !
Re: Assembled TF536 - help needed
I suspect you have more than one badly soldered pin on the cpld. Also if there is a problem with the ram buffers you'll get no ram detected.
Have you tried Diagrom?
Maybe post some photos of your board here and we will have a look.
You get this issue when the RAM is completely dead.
Have you booted DiagROM and looked at the address range 0x40000000 to 0x44000000?
sampedenawa
Thanks for your immediate feedback !
@Stephen
I ran diagrom, and it did not detect anything in the range you quoted. It only detect chipram and anything else.
Here alleged a few pics (hope the detail is enough).
Sorry for the board still not completely clened from flux.
Any further suggestion much appreciated.
Image Image Image
@sampedenawa in your photos its hard to tell but it looks like there are bridges across some of the cpld pins.
PaulJ_2.0
Post by PaulJ_2.0 »
Flood with flux (too much) and reflow the ram and cpld.
sampedenawa wrote: 01 Nov 2020 12:34 @Stephen
Did you *look* at it with the memory viewer?
sampedenawa
PhilC wrote: 01 Nov 2020 12:57 @sampedenawa in your photos its hard to tell but it looks like there are bridges across some of the cpld pins.
PaulJ_2.0 wrote: 01 Nov 2020 13:16 Flood with flux (too much) and reflow the ram and cpld.
Probably is a combination of flux remains and (too) low details of the pics, but I checked the pins of the cpld with a digital uscope, and I did not find any evident bridge.
terriblefire wrote: 01 Nov 2020 13:52 Did you *look* at it with the memory viewer?
Here is the result:
Image Image
Anyway, I will follow the advice form PaulJ_2.0, may some hidden bridge which could vanish by doing this.
Lateral thinking: any chance to have a counterfeit CPLD ? Could it be a plausible scenario ?
Will update later this evening.
Thank you all for now !
Well we can tell you exactly which pins are bridged if you do a complete memory detection and try editing the memory and see which byte lanes arent happy.
This is the 4th or 5th thread with exactly the same symptoms. all 4 were resolved using memory editor, complete memory detection and some magnification.
@sampedenawa please stop externally linking to photos. Its against the forum rules. if you do it again the thread will be deleted.
Return to “TF536”
Users browsing this forum: ClaudeBot and 12 guests
