H5 A3 JUMPERS
Information and progress towards the H5 board.
H5 A3 JUMPERS
RAM SIZE SELECT
Can force the RAM to the selected amount.
ROM BANK SELECT
BLITTER
JP15, JP16 both linked when no blitter is installed.
ROM DECODING SELECT
Default is linked to enable ROM to decode TOS104 as normal.
Use the right pad only to drive ROM CE externally for TOS206 etc.
FLOPPY DS HD MODE SELECT
Note you have to have the floppy GAL installed to use these modes.
FLOPPY GAL 8&16Mhz SELECT
Note you have to have the floppy GAL installed to use 16MHz modes.
16MHz GAL JUMPER
Not yet tested! If not fitting the 16MHz OSC, you can jumper SJ13 to feed 16MHz from the shifter instead.
Re: H5 A3 JUMPERS
MONO / COLOUR SELECT
FIX PINS 2&3 need to be soldered together on the bottom of the PCB..
1&2 OPEN = AUTO / RGB MODE
1&2 CLOSED = FORCE MONO MODE
NOTE: Pin3 (also soldered to pin2) is connected to the MONO pin as normal on the RGB socket. So plugging in a MONO minitor will auto switch to MONO mode as standard operation.
Re: H5 A3 JUMPERS
JP5 SOUND DECODER ENABLE
Default = Linked for GLUE decoding.
Re: H5 A3 JUMPERS
JP17 DRIVE AB SWAP
Re: H5 A3 JUMPERS
JP9 HSYNC SELECT
Closed = GLUE HSYNC enabled.
Open = Reserved for future use with the HDMI shifter.
VSYNC pad = Reserved for future use with the HDMI shifter.
Re: H5 A3 JUMPERS
JP2 & JP22 BLANKING SELECTS
Default setting is indicated by a line between jumper pins.
Re: H5 A3 JUMPERS
JP14 FLASHY CLOCK
The highlighted middle pins are to be wire linked if flashy clock is not used.
Re: H5 A3 JUMPERS
SJ1 KEYBOARD ERROR CLICK ON / OFF
By default, when the keyboard is not connected you get a constant key clicking sound, basically indicating you forgot to plug it in normally! I actually think this is a useful thing to have, but others think this is incorrect and it should not do that. So if you are one of those people, you can disable that "feature".
Re: H5 A3 JUMPERS
JP20 KEYBOARD LED SELECT
Re: H5 A3 JUMPERS
JP3 MIDI SOUND OUTPUTS
DO NOT JUMPER. RESERVED FOR FUTURE USE.
Locked
Return to “H5 Phoenix Platform Edition”
