I did try both, with overriding BFE I had terrible slowdown, so I checked eagle schematic and found thst Fire0/1 were connected. Then I battled a little to find out that those pins need to be set up as Open drain (on push-pull Diagrom doesn't boot), and now I settled on Fire0/1 ... at least for now.terriblefire wrote: 26 Oct 2020 22:23 Can i check.. are you decoding / overriding BFE001? I'm not certain you need to as you can output on FIRE0/FIRE1 instead?
arkadiusz.makarenko
- Moderator Team
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Well personally I think having Keyboard, Mouse and Joypad support via the riser as wireless *and* being able to view FMV from the 23D is my ideal setup. The board has room for future tinkering too . so its double win.
Currently the new boards are sitting in Germany waiting to clear customs.
wairnair
sry for my ignorance but what's 23D?
Yeah.. with this new riser the CD32 will certainly be my childhood's dream Amiga - plus some more (didn't even think wireless back then)
- Admin sponsor
23 pin Dwairnair wrote: 27 Oct 2020 15:36sry for my ignorance but what's 23D?
arkadiusz.makarenko
- Moderator Team
I have ordered DB23s on eBay, and I would like to order stuff in Mouser to complete this(and parts to finish my A500++ build) soon, what do I would I need to order? All parts or connectors and cpld like last time?terriblefire wrote: 27 Oct 2020 08:55 Currently the new boards are sitting in Germany waiting to clear customs.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Should just be connectors and CPLD like before. I have the video chips so i'll solder that on for you. No idea if that will work btw..arkadiusz.makarenko wrote: 27 Oct 2020 17:22I have ordered DB23s on eBay, and I would like to order stuff in Mouser to complete this(and parts to finish my A500++ build) soon, what do I would I need to order? All parts or connectors and cpld like last time?terriblefire wrote: 27 Oct 2020 08:55 Currently the new boards are sitting in Germany waiting to clear customs.
- Admin sponsor
OK so i had an ARM expert look at your code @arkadiusz.makarenko.. .specifically why its slow. Jamie doesnt pull punches so take a breath.
^ Don't do that. Write PORTB in one go.
https://github.com/arkadiuszmakarenko/T ... ain.c#L740 because he goes through the HAL which involves a lot of dicking about with an I/O setup structure on every write instead of poking the data direction registers.
Jamie: Also he's setting one pin at a time. With a function call for each pin. Fix that one function.
Jamie: Once the port is generally set up, you only need to toggle input/output modes.
Jamie: Which is one 32-bit write.
Jamie: Also going pin-by-pin involves messing about with the single-pin set/reset registers vs. putting all the data into one value and writing it to the port data reg in one go.
//Put data on 8 bit section of databus
for (int i=0;i<8;i++)
//Write Pin method compared to Init should be fast enough
HAL_GPIO_WritePin(GPIOB,1<<i,(data&(1<<i)));
Jamie: Need to just add some sensible bulk read-the-whole-port functions.
Jamie: All the registers for doing it are defined in
https://raw.githubusercontent.com/arka ... 32f722xx.h as they should be.
- Admin sponsor
Anyways thats why its horrifically slow. Need to impement a ReadPort and WritePort function and use them.
this could be changed to
then you can mask off the bits you want.
ReadData can just become a macro
#define ReadData {GPIOB->IDR & 0xFF;}
or make it an inline function.
GPIO_PinState HAL_GPIO_ReadPin(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
GPIO_PinState bitstatus;
/* Check the parameters */
assert_param(IS_GPIO_PIN(GPIO_Pin));
if((GPIOx->IDR & GPIO_Pin) != (uint32_t)GPIO_PIN_RESET)
bitstatus = GPIO_PIN_SET;
else
bitstatus = GPIO_PIN_RESET;
return bitstatus;
// Dont even call the function..
data = GPIOB->IDR;
arkadiusz.makarenko
- Moderator Team
Code review is always welcome.
Thank you.
This make perfect sense!
Initially I had code to redefine Data GPIOs directly on registers as it is one GPIO port and entry and exit settings are fixed. But I wasn't sure about some settings so using HAL is easier to adapt and check if it is what I need. It will be easy to change now as I know exactly what need to be done.
What I didn't think of is reading/writing whole Data/Address values at once from register, this will reduce amount of cycles dramatically. I assumed GPIO reads/writes are fairly cheap, what I didn't think of is that formatting data + cheap read/write times 5 (addresses) + 8(data) is not cheap any more.
Thank you.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Also if you look at what GPIO init does its *ALOT*.. you probably want to make a cut down version of it. You do it twice in WriteData()arkadiusz.makarenko wrote: 28 Oct 2020 12:51 Code review is always welcome.
Thank you.
for(position = 0; position < GPIO_NUMBER; position++)
temp = GPIOx->PUPDR;
temp &= ~(GPIO_PUPDR_PUPDR0 << (position * 2));
temp |= ((GPIO_Init->Pull) << (position * 2));
GPIOx->PUPDR = temp;
