Old Glue and MMU compatibility
Evening All,
Just a quick question. I've got a Rev C C070243 with the -20 glue and mmu. I think the mmu has died. Are these compatible with the -38 versions?
Re: Old Glue and MMU compatibility
Never heard of a -20 glue ?
exxos wrote: 19 Oct 2020 21:49 Never heard of a -20 glue ?
Here ya go. Writing is out 90 degrees
czietz
Post by czietz »
Yes, they are compatible.
The first STs has a chipset made by Universal Semiconductors: https://temlib.org/AtariForumWiki/image ... jokker.jpg
@czietz thanks, it did look like they would be but wanted to check.
czietz
Post by czietz »
In case it's really broken, do you mind -- instead of tossing it into the bin -- sending it to me? (I can pay for the postage.) I always wanted to (try to) decap a -20 IC, but they're so rare...
czietz wrote: 19 Oct 2020 21:58 In case it's really broken, do you mind -- instead of tossing it into the bin -- sending it to me? (I can pay for the postage.) I always wanted to (try to) decap a -20 IC, but they're so rare...
If its really broken then no problem, will do as long as you share the results :D might throw in a -20 glue as well.
troed
Post by troed »
The -20 GLUE has "short top border" (PAL screen starts higher up on the TV/monitor than on the later revision)
A lot of demos will fail to remove upper border/start fullscreen on those machines.
/Troed
czietz
Post by czietz »
PhilC wrote: 19 Oct 2020 22:21 If its really broken then no problem, will do as long as you share the results :D might throw in a -20 glue as well.
Sure, if it's not broken, please keep it. In that case it can be better used than for decapping.
W.r.t. sharing the results: It depends on what you expect. I cannot take beautiful high-res die photos like ijor did for the Ricoh (-38) chips (https://www.fpgaarcade.com/wp4/wp-conte ... OP-50X.jpg) because the good microscope lacks a camera and my USB microscope lacks the magnification. Still, I would like to find out if these chips are really Universal Semiconductor gate arrays and thus I'm hoping for a logo and/or part number on the die.
EDIT: So my die pictures tend to look like this (non-Atari chip):
Finally got this machine working, although its stuck in mono mode so got to fix that.
Now I know that the early glue and mmu SHOULD be compatible with the -20 versions as we've discussed earlier in this topic BUT after fixing other issues with the ST I finally got the white border with black foreground, ie memory fault.
I swapped out the -38 mmu and glue for the originals and the machine booted up just fine. So it appears there are differences between the old and current version. No idea what yet though.
Users browsing this forum: archive.org [bot], ClaudeBot and 12 guests
