Service blog for this PSU recap using Exxos kit for customer.
New cap kit:
PSU casing:
PSU before recap:
PSU after recap:
PCB underside:
Finished, with old caps in a bag:
Will run some tests on it later.
Phihong PSM-5314 PSU TT Recap
Re: Phihong PSM-5314 PSU TT Recap
Tests ok:
czietz
Note that if this PSU is ever intended to go into a Mega STE, the optocoupler should be changed. Search the older threads for possible replacement part numbers. The optocoupler in the pictured PSU is known to cause 50 Hz output ripple that becomes visible as slight flickering of the screen in the MegaSTE in monochrome mode.
Thank you for the information. This is TT only. So is the PC111 a recommended optocoupler for both MSTE and TT?czietz wrote: 13 Oct 2020 17:14 Note that if this PSU is ever intended to go into a Mega STE, the optocoupler should be changed. Search the older threads for possible replacement part numbers. The optocoupler in the pictured PSU is known to cause 50 Hz output ripple that becomes visible as slight flickering of the screen in the MegaSTE in monochrome mode.
czietz
Yes, it is.Steve wrote: 13 Oct 2020 18:29 Thank you for the information. This is TT only. So is the PC111 a recommended optocoupler for both MSTE and TT?
Disclaimer: Of course, like with any PSU work, be sure to re-test with the dummy load after changing the opto-coupler to be sure that the output voltages are correct.
Thanks @czietz, I've placed an order for this new optocoupler. Seems to be a good idea :)
Be interesting to see before and after ripple... But also dips in voltage when the floppy drive motor turns on..
Users browsing this forum: ClaudeBot and 18 guests
