TF CD32 Riser
arkadiusz.makarenko wrote: Mon Oct 12, 2020 11:13 pm That is what I did try, already.
I need to measure exti latency....
I even can't read meaningful data from the bus. :(
Time for a break and regroup I think. :D ... it was worth a try. (Need to get a little bit better with verilog)
EXTI latency is not the issue. It could sit there for a month... no issues. You want it to be short for performance but You read the mouse and joystick once every 1/50th of a second and you read the RTC once at boot time. So speed isnt critical.
The issue is that when you ACK the ARM is still putting data on the bus. So the next instruction fetch crashes.
I suspect the bus isnt getting tristated again.
You could try put data on the bus... when you ack latch it into the cpld... then read it from the cpld on some other random address.
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
terriblefire wrote: Mon Oct 12, 2020 11:37 pm
Now I got triggered. :D
I must do something really stupid there...
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
BUAHAHAHA!!!!! It's ALIVE :D
Edit: I was not handling DSACK correctly. This one hold 0/1 high till ARM tell it to change DTACK0 to low.
And on ARM side I do reprogram gpio back to open drain before I send ACK to CPLD. It must takes few cycles before it actually happens so cd32 have enough time to latch data.
~ Stanislaw Lem
Nice work. Now you can do everything you need from ARM. just used different INTSIG for different addresses.
terriblefire wrote: Tue Oct 13, 2020 11:07 am Nice work. Now you can do everything you need from ARM. just used different INTSIG for different addresses.
If you tell me all the pcb changes needed for the RTC and Vcap i'll update the github repo
arkadiusz.makarenko
Moderator Team
Moderator Team
terriblefire wrote: Tue Oct 13, 2020 2:28 pm
I will, but need to get my head round all RTC options. Just touched the subject few months ago. Need to refresh my memory on it.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Tue Oct 13, 2020 3:28 pm I will, but need to get my head round all RTC options. Just touched the subject few months ago. Need to refresh my memory on it.
No worries. I think you mentioned you needed another oscillator?
I'll sort the video out and let you get back to me on the oscillator.
I'm considering this part for buffering the video output..
https://uk.rs-online.com/web/p/video-buffers/4972511/
and
https://uk.rs-online.com/web/p/video-buffers/1627539/
May end up going with a part that JLCPCB has supply of rather that the "best" chip.
e.g.
https://datasheet.lcsc.com/szlcsc/3PEAK ... 155447.pdf
I have pushed the changes for the Vcap to github. let me know if you want the crystal changed etc.
We need to figure out what you meant here..
https://www.exxosforum.co.uk/forum/viewt ... d32#p37462
LSE oscillator was missing i think?
Return to “TF CD32 Riser”
