Micronik RA-501
GianDO
Micronik RA-501
Hi,
I found a Micronik RA-501 to expand the A2000 chipram to 2MB, but I don't have the schematic to connect the two wires to Gary chip. If any of you have it, could you please provide it to me?
Regards
GianDO
Regards
GianDO
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
- Admin sponsor
Re: Micronik RA-501
Best chance is looking at
Which looks to me to connect to pins 38 and 37 below..
Which would make sense. It probably doesnt matter too much which order they are in. Or at least it will not do damage if the order is reversed since the extra ram would just be used in a different pattern. If you find its not happy try swapping them.
- Admin sponsor
Re: Micronik RA-501
Quick maths check...
To address 2Mb of RAM you need 22 bits A[21:0] so my guess would be those are connected to A21 (37) and A20 (36).
A similar product is also hooking wires to this chip.
https://pmsoft.nl/amiga/mega-chip-two.html
Like i say you will not cause damage by connecting to the wrong address pin (provided you stay on an address pin) but it may not function as expected.
GianDO
Re: Micronik RA-501
ok, thanks for the reply.
So do I have to unplug Gary's pin 32 as well as shown in the last photo?
- Admin sponsor
Re: Micronik RA-501
No that just happened to be in the image i found. You can ignore that.GianDO wrote: 12 Oct 2020 19:31 ok, thanks for the reply.
GianDO
Re: Micronik RA-501
ok thanks I'll try to follow your instructions.
- Admin sponsor
Re: Micronik RA-501
Please let us know how you got on and what worked/didnt.
- Admin sponsor
Re: Micronik RA-501
Adding some more pictures i found of this board
- Admin sponsor
Re: Micronik RA-501
Looking at the last image I count (please check me) the 12th and 13th pin from the top as the address pins...
That ties up to my theory of pins 36 and 37. (Again please check me).
GianDO
Re: Micronik RA-501
terriblefire wrote: 13 Oct 2020 09:19 Looking at the last image I count (please check me) the 12th and 13th pin from the top as the address pins...
You were right about everything. I made the connections as you suggested and everything worked fine. Thanks for the advice and suggestions.
Also I confirm that even if you reverse the connections Gary everything works fine.
Thank you very much
G
